Go to Post Unfortunately, not everyone is Andy Baker. If everyone had this mindset, there would be far fewer problems. - Kevin Kolodziej [more]
Unread 07-02-2005, 00:24
Grizzlie's Avatar
Grizzlie Grizzlie is offline
Grizzlie is an unknown quantity at this point
Post Solenoid control
I am trying to program the solenoids this year to wherewhen i hold the trigger it activates and when i let go it deactivates. Same as the reverse motion. I wrote this code to do this but it wont work. When i press the trigger the solonoid activates but when i let go it doesnt stop. And it WILL NOT go back when i press the rev button. heres the code i wrote :
 if (p3_sw_trig);
      relay3_fwd = 1;
if (!p3_sw_trig);
      relay3_fwd = 0;
if (p3_sw_top);
      relay3_rev = 1;
if (!p3_sw_trig);
      relay3_rev = 0;
It would be great if someone could explain to me what i did wrong here because i'm fairly new to the C language. But it would be even better if someone could post the exact code to make this work. Thank You for even taking your time to read this post. And also good luck this year!
"Act Quickly , Think Slowly" - Greek Proverb
Unread 07-02-2005, 00:35
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Solenoid control
 if (p3_sw_trig);
      relay3_fwd = 1;
if (!p3_sw_trig);
      relay3_fwd = 0;
if (p3_sw_top);
      relay3_rev = 1;
if (!p3_sw_trig);
      relay3_rev = 0;
Well, I see three immediate problems. One, all of your if statements end in semicolons. That is bad. Two, your last if statement checks !p3_sw_trig instead of !p3_sw_top. Three, I would suggest using else statements, rather than the structure of if statements that you've chosen. Try this:
if (p3_sw_trig)
      relay3_fwd = 1;
else
      relay3_fwd = 0;
if (p3_sw_top)
      relay3_rev = 1;
else
      relay3_rev = 0;
If you wanted, you could simplify this even further:
relay3_fwd=p3_sw_trig?1:0;
relay3_rev=p3_sw_top?1:0;
Simpler, though not quite as easy to read.
<edit>
Hm... now that I think about it, you might even be able to do:
relay3_fwd=p3_sw_trig;
relay3_rev=p3_sw_top;
I don't have an RC with which to test that, but I know the other two methods will work just fine.
</edit>
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 07-02-2005, 00:44
reilly reilly is offline
reilly is an unknown quantity at this point
Here is the way to do this:
if (p3_sw_trig) //no semi colons for functions
relay3_fwd = 1;
else (!p3_sw_trig)
relay3_fwd = 0;
else if (p3_sw_top) //or if is fine here also
relay3_rev = 1;
else
relay3_rev = 0;
Unread 07-02-2005, 17:41
Grizzlie's Avatar
[quote] Two, your last if statement checks !p3_sw_trig instead of !p3_sw_topQUOTE]
o yea that isnt the problem because i didnt put that there i kinda just that laswt bit of code from memory. but the semicolon would explainthe syntax errors . Ok im gonna try your code and hope it works. Thanks!
Unread 16-02-2005, 17:35
Grizzlie's Avatar
where in the user_routines.c would i put this code? or is there a diiferent file where this code would belong?
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 10-03-2005 21:29
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
