Go to Post Welcome to FIRST. You've never seen anything like this. - Aignam [more]
Unread 16-02-2005, 18:45
h0x4r h0x4r is offline
h0x4r has a little shameless behaviour in the past
Thumbs up Re: joystick sensitivity
i just decreased the limit mix to the joystick drive, which should be at 2000 when to begin with, so it will move less when u move the joystick, using the normal white joysticks
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
