Go to Post ..."A bad day at college is always better then a good day at work" - KyleGilbert45 [more]
Unread 16-02-2005, 18:49
h0x4r h0x4r is offline
h0x4r has a little shameless behaviour in the past
joystick buttons and a quick question
first of all, are u allowed to take code with u then upload it to the robot there, and the 3 buttons on the joystick, not the trigger and thumb button, how do u call those in code and use it for the robot?
Unread 17-02-2005, 00:06
Re: joystick buttons and a quick question
First, you're only supposed to do software development when it's legal to work on the robot. That means during the six-week build, at competitions, and during the "fix-it window" after each. You can do analysis and prototyping any time you want, but you're not supposed to write actual code to be installed on the robot.
Second, the joystick switch to the left of the "hat" is p#_sw_aux1, the one to the right is p#_sw_aux2, and the hat itself is an analog value on p#_wheel that changes depending on which direction it's being moved.
Unread 17-02-2005, 00:18
thxs
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
Alternate Joystick question archiver 2001 5 24-06-2002 00:01
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
