Go to Post Who doesn't love a good Finger Lakes Regional?! - LeelandS [more]
Unread 16-02-2005, 19:22
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Only one side moving
We have tank drive and when I move one joystick it goes forward but when I move the other one the motors do not move at all. I dont know if it is a programming thing I need to add or remove, but I need help!
Unread 16-02-2005, 19:26
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Only one side moving
make sure that you have the right PWMs matching up with the code and the electronics...
And make sure that you have the right y-values setting the PWMs, and make sure they go to the hooked up joysticks.
- from B B frank
Unread 16-02-2005, 19:57
FRC #1706
Team Role: Driver
They are all in the right spots, ive tried pretty much eveything, we replaced the wires also so that didn't work.
Unread 16-02-2005, 22:49
FRC #1706
Team Role: Driver
The shipping date is pretty soon and this is a big problem, I have tried many different things, please if you have a suggestion, post it!
I have two joysticks. One going to Port 1, one going to Port 2. The Port 2 joystick with pwm02 works and the whole left side works. Port 1 and pwm01 do not work though. The whole righgt side just sits there.
Unread 16-02-2005, 23:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Make sure you aren't setting your motor back to 127 (or the value of some other input device) after you set it to the joystick value.
http://www.mikesorrenti.com/
Unread 17-02-2005, 01:59
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
Check out Victor 884's Guide. There is good information on how to troubleshoot the speed controllers.
Check the light on speed controller for pwm 1. If it doesn't come on I would check to make sure you have a fuse in the right spot on your fuse board and check the trim on your joystick. If it is flashing orange (when robot is enabled) it means that the Victor is not receiving a signal from the PWM's; check your PWM connections. Are they in tight? Are they in the right way?
If all that checks out ok then push your joystick full forward. The light on the Victor should turn green. Then go full reverse; light should turn red. If you are getting this and the robot is not moving then check your motor connection and check the voltage at the motor(s).
Hope this helps!
Any controls people out there, feel free to correct any of my mistakes. My heart is in the mechanical side of things.
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 17-02-2005, 15:09
FRC #1706
Team Role: Driver
None of that works. the speed controlers do not change colors, the trim doesn't work, the fuse is in the right spot.
I was thinking maybe a bad wire, Ill try that tonight if we have an extra.
Unread 17-02-2005, 15:36
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
Check your joysticks- we had the same problem, and apparently we received 2 faulty joysticks.. if the victors arent getting a signal (solid yellow), then check joystick/OI/- if they are flashing yellow, check PWMs, if they are chagning color, check wiring coming out of the back end of the victor to the motors- no light at all, check fuses/ wiring from breaker panel to victors
Unread 17-02-2005, 16:59
FRC #1706
Team Role: Driver
The vitors are solid yellow. The Joystick on the OI for Joystick 1 (which is the one that doesn't work) has the green and red come never come on. The Joystick 2 has Green and Red on at all times. I dont think the joysticks are faulty because both triggers on the joysticks work. Any suggestions for maybe programming? I have
pwm01 = p1_y;
pwm02 = 255-p2_y;
Also the 1 joystick drive part of the default code is commented out.
Unread 18-02-2005, 09:33
FRC #4976 (Rebels)
Sounds like it's time for a little process of elimination.
Step 1:
Swap joysticks from port 1 to port 2. If motors on the other side start working then you have a faulty joystick. If you have the same problem then proceed to step 2.
Step 2: Swap the pwm wire from pwm1 to pwm 2 on the robot controller. If the other side starts working then you have a programming or hardware problem with your robot controller. If you have the same problem then proceed to step 3.
Step 3: Swap the motor output wires from the two Victors. If the other side starts working then you have a Victor problem. If nothing changes then proceed to step 4.
Step 4: Swap the motor leads from the two motors. If the other side starts working then you have a wiring or connection problem. If the nothing changes then I would try a new motor and check that the wheels can be turned by hand (not locked mechanically).
A lot of these steps can be checked with a multimeter as well.
Hope this helps!
Derek Bessette
Unread 18-02-2005, 11:31
If you're using the default code I think you are, the top OI feedback lights are telling you when the joystick is centered. It sounds like it thinks the second joystick's y axis isn't connected. Swap joysticks between port 1 and port 2 and see if the problem follows the joystick.
Unread 21-02-2005, 00:00
FRC #1706
Team Role: Driver
We came to the conclusion that the Y-Axis on one joystick is faulty(isthat even possible?). The buttons, and X-Axis and all the work except Y axis, soooo thanks for the help.
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
Mounting weights on the side of the bridge? archiver 2001 0 23-06-2002 23:00
Goal on side... What's the final word! archiver 2001 4 23-06-2002 22:39
Goal moving devices fs_2002 Technical Discussion 5 27-01-2002 19:55
How moving goal while picking up balls Matchew General Forum 14 22-01-2002 22:22
