Go to Post There are so much more things to be worked on and are more beneficial to FIRST and FIRSTers than green dots by someone's name. - tiffany34990 [more]
Unread 16-02-2005, 20:34
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
missing old_port
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - could not find definition of symbol 'Old_Port_B' in file 'C:\1008\build\interrupts.o'.
Errors : 1
what's wrong here?
Unread 16-02-2005, 22:29
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Re: missing old_port
What you just got is a linker error. Linker errors generally talk about variables or functions that are not found anywhere and are often cryptic. Usually your best way to solve them is to use the "Find in project files..." option and search for the variable or function in question and find out how they are used.
Usually they result from typos or missing files. If you see a warning like "Implicit definition of function" then that means that you do not have a "header" file with the fuction delcared in it. This often results in such linker errors.
In this case, just declare an int variable called "Old_Port_B" at the top of interrupts.c so that the linker will find it.
int Old_Port_B;
Just make sure that you declare it outside of a function because the linker does not look in local variables.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 17-02-2005, 10:09
Originally Posted by stephenthe1
MPLINK 3.90, Linker
Errors : 1
what's wrong here?
Search your project for references to that symbol. Here's the clue in the interrupts.c file:
	Old_Port_B = PORTB;			// initialize the Old_Port_B variable (in user_routines_fast.c)
Immediately after all the #includes in user_routines.fast.c, you should have this:
unsigned char Old_Port_B = 0xFF;// state of port b the last time
				// this function was called
It's there in the downloaded frc_interrupts example. You probably copied what you thought was important from it into your own files, and missed this one.
Who's missing parts? sanddrag Kit & Additional Hardware 37 12-01-2005 12:13
Transmission missing pieces?? Brandon Holley Technical Discussion 2 10-01-2005 17:13
Who is missing stuff from KOP? Matthew_H Kit & Additional Hardware 52 05-02-2004 19:52
Receiving missing parts from KOP shyra1353 Kit & Additional Hardware 7 30-01-2004 00:58
Anyone missing as many parts as we are? Drew Hopman Technical Discussion 4 19-01-2004 19:06
