Go to Post I've always thought that what makes an average person exceptional is not their inability to make mistakes, but rather their ability to recognise, rectify, and learn from them. - artdutra04 [more]
Unread 17-02-2005, 01:54
CompMaster CompMaster is offline
CompMaster is an unknown quantity at this point
How do I enter the Autonomous mode?
we are working on regular form how do we enter the Autonomous mode?
(how can I enter the Autonomous mode?-how do I use it?)
Unread 17-02-2005, 02:00
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: How do I enter the Autonomous mode?
There are two methods, you can connect ports 6 and 8 on the OI to start autonomous mode, disconnect to stop (Many teams use an on and off switch to short the two pins) -- there are diagrams floating around (do a search) on how to make an autonomous dongle/faker, also since you are working with the competition port, you run the risk of messing up your OI if you do something wrong.
Another method is to set the team number on the OI to 0, tether the OI to the RC, then disconnect -- to stop the autonomous mode, set the team number on the OI to anything but 0, then re-tether. It's a safer way, but if the robot goes bezerk and you lose the tether then many bad things can happen.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 17-02-2005, 03:11
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
we set our team number to 0, tethered bot, uploaded code, un tethered, and veen pressed reset (which i assumed only restarts the bot) and yet it does not work. we also changed team number, tethered, turned off bot, untethered, and turned bot on and we could not get it to work.
-Rookie plz bear with me thanks!
Unread 17-02-2005, 03:18
24 Hours of LeMons?
Here's more detailed instructions:
-Set the team number on the Operator Interface to 0 (Both robot and operator interface should be powered, preferably no radio connection).
-Tether OI to Robot Controller (This should set the team number on the RC to 0).
-Disconnect tether from OI or RC (the robot should be running autonomous).
To stop autonomous:
-Set the team number on the OI to any number but 0.
-Re-connect tether.
If it doesn't work, try using the autonomous faker that many other teams use. Read this document for more information.
Unread 17-02-2005, 03:19
Kurayami o Samayou
None #1160
alright thanks
Unread 17-02-2005, 19:12
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
Why not just use this?
while (p2_sw_aux1 == 1 || autonomous_mode) /* DO NOT CHANGE! */
Total joystick control!
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Wolrd Triple Play Autonomous Mode (WAM) Standards Natchez General Forum 3 11-01-2005 15:52
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
