Re: Use of Functions in Autonomous
I didnt want to create another thread for this so heres a question for you guys. I am using two encoders and a gyro and am going to run the scripts from the command.h file. Now, to call those functions to see if they work will this code work in my user_routines_fast.c file:
while (autonomous_mode) /* DO NOT CHANGE! */ { if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */ { Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */ /* Add your own autonomous code here. */ if(rc_dig_in16 = 1) { robot_control(); } Generate_Pwms(pwm13,pwm14,pwm15,pwm16); Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */ } } } |
| Updated: Serial Port Driver Code | Kevin Watson | Programming | 4 | 05-02-2005 18:39 |
| Wolrd Triple Play Autonomous Mode (WAM) Standards | Natchez | General Forum | 3 | 11-01-2005 15:52 |
| Despite what IFI says, you can configure autonomous from OI... | TedP | Programming | 19 | 31-03-2004 10:09 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
