Go to Post The secret to this whole thing is that it's the robot that builds the team. - JohnBoucher [more]
Unread 15-02-2005, 20:24
neilcooper neilcooper is offline
neilcooper will become famous soon enough
Question borland?
does anybody know of a first loader that works with borland compilers?
Unread 15-02-2005, 22:48
TMHStitans TMHStitans is offline
Robot Operator-2005
AKA: Eric
#1474 (Tewksbury Titans)
TMHStitans has a little shameless behaviour in the past
Re: borland?
no, i dont
Unread 16-02-2005, 01:41
Re: borland?
Does Borland even make a PIC compiler? I've never heard of one.
Unread 16-02-2005, 01:47
Darwin695 Darwin695 is offline
#0008 (Paly Robotics)
Darwin695 is an unknown quantity at this point
Send a message via AIM to Darwin695
C18 is the only thing you are going to use...
Sadly, Innovation First decided not to put an x86 based computer system in the robot controller this year, that means you are going to have to use a compiler made for a PIC Processor (specefically the pic18f... serries with the 8x8 hardware multiply...) the easiest compiler to use in this case is the supplied C18 compiler.
If you do find another compiler for PIC's that you like, i would love to know about it... the C18 is a little on the expensive side when you arent using it for robotics...
-Cheers
I build it,
My brother destroys it
Unread 17-02-2005, 14:14
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: borland?
I think what he want is an IFIloader replacement, and not a PIC compiler.
No I don't know of any. Are you up to writing one?
Unread 17-02-2005, 14:23
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: borland?
It's important to understand whats happenens when compile and download software.
1. You select Build All in MPLAB. MPLAB the Integrated Develeopment Enviroment (IDE) send commands to the PIC C18 compiler to compile and then link your code. This creates a hex file. The hex file is a file that is machine code for the PIC processor inside the IFI Robot Controller. Machine code is similar to an .exe file on your computer.
2. You open up the IFI Loader, select your file, and hit download. The Master Processor haults everything else on your robot and enters a boot loader mode. A boot loader allows you to download the program into the Robot Controller's memory. Once complete, your program executes.
Unread 17-02-2005, 14:57
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: borland?
True, but he said specifically for a borland compiler, and borland compiler is not the right assembly code (not the text, the actual bits used by the computer), and it would not work without a compiler specifically for the PIC, unless it was converted from x86 to PIC, which would be another interesting program. So the PIC would read the bits and think that it is running something completely different from the compiler, and programmer think that they are writing.
- from B B frank
Any pratical use for Microsoft Visual Studio .NET Pro Kyle Fenton General Forum 11 28-01-2003 16:59
