Go to Post Along with having good manners, having good judgement goes a long way in life. - ebarker [more]
Unread 17-02-2005, 14:41
Chuck Merja Chuck Merja is offline
Chuck Merja is an unknown quantity at this point
compile error
We have been getting some help from a new found friend on the programming side. Last night he came to help and was plugging in some auto mode, but got the following error...
Executing: "C:\Program Files\MPLAB IDE\MCHIP_Tools\mpasmwin.exe" /q /p18F8520 "mcmpp2p.asm" /l"mcmpp2p.lst" /e"mcmpp2p.err" /o"mcmpp2p.o" Error[101] C:\MCC18\SRC\STRING\18CXX\MCMPP2P.ASM 102 : ERROR: (No Model Specified) Halting build on first failure as requested. BUILD FAILED: Wed Feb 16 20:43:52 2005
Rookie team 1696, frosh team, volunteer mentor, not a software guy, did spend time readling threads, didn't find answers, getting a bit tense - deep breathes... help would be appreciated.
Unread 17-02-2005, 14:48
jdhawg's Avatar
jdhawg jdhawg is offline
Programmer/Mentor/Parent. Pick One
AKA: Jack D Higgs
FRC #0364 (Team Fusion)
jdhawg will become famous soon enough
Re: compile error
1. Did it compile before your friend added the autonomous code?
2. If this is the first time you've tried to compile, did you make sure to set the project up for C instead of assembler?
#1 is important, because if it worked and then stopped you need to go back to your backup (hey, I've been programming for 22+ years and I NEVER backup anything up) and try again.
#2 is a problem we had the first time we tried to compile anything. The IDE thought we were programming in assembler and wouldn't work until I changed to project to C.
Good Luck!
"Opportunity is missed by most people because it is dressed in overalls and looks like work." - Thomas A. Edison
"In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits." - Dave Lavery
Unread 17-02-2005, 15:01
gemccnp gemccnp is offline
gemccnp is an unknown quantity at this point
Red face Re: compile error
jdhawg, thanks for your input. I am working with Chuck and the programming on team 1696.
When you mention "C", is it in reference to a setting in MPIDE? I have the code on my laptop and can try it now. Or, do I need a different compiler?
Thanks again for the help, this is the last step in the software prep.
Sincerely
George Murphy
Team 1696
Unread 17-02-2005, 15:02
Re: compile error
thanks for the quick reply -
btw - the compiler seems to work for several minutes before getting the error message
re 1 - the prior code was default, although not compiled on this machine, so I think we have never successfully compiled anything on this machine.
re 2 - don't know, will check when I go in today.
error with adc.h incognito_NICK Programming 2 05-02-2005 23:27
InterruptVectorLow error when we compile Redneck Programming 5 02-02-2005 22:57
MPLink Error cloudago Programming 2 01-02-2005 23:00
Compile error blindguyinanorg Programming 4 12-02-2004 19:49
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
