Go to Post Starting from scratch is what makes it hard. - ChrisH [more]
Unread 15-02-2005, 08:53
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Problem w/Mesh
We have problems with some objects that were created in 3ds max 6. When we group them the group cannot move, rotate or scale. When we try to link them the parent can be moved, but the children don't follow.
We were hoping bringing the file into max 7 would solve the problem, but the strange behaviour is still there.
This is not a problem on new stuff created in max 7; just the stuff started in 6. Most of the objects would be simple to recreate, but one mesh would take a long time duplicate.
We sorta solved the problem by exporting, then importing a 3DS file, but we loose the modifier stack.
Any other suggestions?
Unread 15-02-2005, 19:59
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
Re: Problem w/Mesh
Have you tried importing the objects into max7 and then re-saving the file?
The only reason I can think of that would not make the group move is the Position controller deleted or you accidentally pressed the spacebar, which locks the objects and prevents you from moving the objects.
If you could post the file, I could try and figure it out.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 17-02-2005, 06:38
AKA: Kevin Thorp
Re: Problem w/Mesh
Yes - I tried to resave in max 7 but the locked groups persist. However anything created new in 7 works fine.
I've attached an example max file. It has a simple group that wont move, rotate or scale.
Unread 17-02-2005, 20:11
kcy88's Avatar
Animator
AKA: Kevin
Re: Problem w/Mesh
Fixed
Ok, here's what you need to do.
1) You can either UNGROUP the objects or OPEN the group
2) select one of the objects
3) In the COMMAND PANEL, click on the MOTION TAB.
4) Select TRANSFORM: Link Constraint... and click on the box just above the window.
5) In the dialogue that pops up, select Position/Rotation/Scale
6) click OK and repeat steps 2-5.
The problem was that you had the wrong Transform controller.
here are some screenshots to help you:
one, two,
three
and here's the fixed MAX file: frozen_group
it should work. if there's any further clarifications that need to be addressed or you're not sure of something, please let me know. I hope i've helped...
Good Luck
Unread 17-02-2005, 23:04
AKA: Kevin Thorp
Re: Problem w/Mesh
Thank you very much KCY! That fixed the problem.
I guess I must have accidentially set the default from position/rotation/scale to link constraint. This locked up all new groups.
Man - there are a thousand hidden settings in this program!
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
