Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 15-02-2005, 19:28
haverfordfords haverfordfords is offline
haverfordfords is an unknown quantity at this point
Exclamation Urgent need for Nason pressure switch!! PLEASE HELP!
DEFECTIVE NASON PRESSURE SWITCH... NEED REPLACEMENT ASAP!!!
Hi,
After several days of trying to figure out why our pnuematics does not work (the compressor will not shut off) - rewring, programming, ect. we have determined that our Nason pressure switch was defective.
We called Nason, and they have a 4-6 week lead time, because apparently, these things are custom made.
We have less than a week to complete our robot, and we can't even see our hard work in action.
We are a rookie team, and we are in dire need of assitance.
PLEASE PLEASE PLEASE PLEASE if anyone ANYONE has a pressure switch they could spare (we can even return it once we get our replacement) you don't know how much we would APPRECIATE this guesture. We'll glady pay for whatever it costs to ship it overnight express, we just need it ASAP!!!!! PLEASE!!!!!!
If you have one or know someone who does, please contact us immediatly.
Thank you in advance,
Jason, Team Leader 1656
Unread 15-02-2005, 20:53
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Urgent need for Nason pressure switch!! PLEASE HELP!
make sure everything is in the right direction (see the arrows on all the regulators)
also make sure that your system matches that in the pneumatics manual, keep in mind that the compressor usual cuts out around 120 psi
Unread 15-02-2005, 21:34
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Have you checked that all of your pressure gauges are in the right place and that you have no leaks. There should be approx 120 in Clippards and 60 down line of the regulator. I would check all of these out first. The rest is wiring and programming. Check were you made your inputs and that your wires are good then check with the programming.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 15-02-2005, 21:49
Thanks for all of your helpful suggestions. However, we tried everything. Upon taking apart the pressure switch (and drilling it apart) it is clear that the switch is stuck in the open position. It will not go to the "closed" position.
Unread 15-02-2005, 22:09
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Have you gotten it to work off of the robot
we have had all of our pneumatics working fine off the robot, but as soon as everything is on the robot almost all pneumatics are not working
our pressure switch also seems to be not working but we are not going to drill it apart
worst comes to worst u can just run the compressor on a timer or something cause it will always vent at about 125
IF anyone can help with problems with the pressure sensor please pm me
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 15-02-2005, 22:17
No, it doesn't work off the robot either, it has never worked, ever - even when directly connected to the battery without going through the system.
We are really looking for someone who can send us a pressure switch, even if its from prior years or anything... If we have to, for the time being we can hard code it like you said, but it would be nice to have the autoshutoff feature =)
Thanks!
Unread 15-02-2005, 22:23
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
It is illegal to not use the Nason Pressure Switch. You must have this wired correctly, if it wasn’t there, your compressor would probably burn out.
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 15-02-2005, 22:35
Grow Up? Why?
Thanks!
Did you wire the battery across the terminals? The terminals are suppose to have a wire that goes to you contoller board that gives an open or closed message to the controller. AT NO TIME should you wire any current across this sensor. The compressor is turned on and off by a spike that is controlled by the main contoller after reading the pressure sensor. I hope that this is of value.
Unread 15-02-2005, 23:06
Oh no, I meant during testing. We have it all hooked up into the main controller and through spikes, the whole deal, we check it a thousand times, we ruled out all the possiblities. It's definetly the pressure switch.
Thanks for your help though!
Unread 17-02-2005, 12:08
dan_h dan_h is offline
EE Grad Student
AKA: Dan Huizenga
#0518
dan_h is an unknown quantity at this point
Thanks!
Directly connecting the pressure switch to the battery could very probably cause the switch to weld itself shut, causing the exact symptoms that you are describing. The way that FIRST specs the pneumatic system, the switch would be handling milliamps. The way you had it hooked up, the switch would be handling amps, causing damage. If you do get a new switch, be sure that you don't ever connect the switch to anything other than a digital input on the RC, or you more than likely will end up with another dead switch.
EDIT:
From your latest post, it sounds like you 'tested' it with something other than the RC. Even if you only connect the switch that way during testing, it would be permanently destroyed. NEVER connect it to anything besides a digital input. If you _really_ want to test it, you can use an ohmmeter across the terminals without worrying about damaging it. It should go to 'zero' when the switch is closed.
Team 518 Home Page
Unread 17-02-2005, 23:31
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
If you still need one, we have a spare. Send me a PM with contact info and address, and we can send it to you tomorrow (but ya gotta promise not to connect it to the battery! )
-dave
Unread 18-02-2005, 00:15
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
If you want to send a driver out to NJ we have the whole pneumatics set not in use and you can pick what you want. We will be at the school all day for the next 4 days. We are in central NJ about 90 mins from you.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 18-02-2005, 02:04
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
-dave
WC
you, sirs, are most definately gracious proffesionals.
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
connecting pressure switch kingpin3787 Pneumatics 2 19-02-2004 21:01
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
