Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 18-02-2005, 00:00
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
500 hundreds of a inch
500 hundreds of a inch, dose A LOT of really bad stuff (to put it in simple form)
our 80-20 got messed up some how??? in two place off by 500 hundreds of a inch WHO KNOW HOW!!!
just take time to fix it NO BIGGIE
Unread 18-02-2005, 00:12
Zippiot Zippiot is offline
punching bag
Zippiot can only hope to improve
Send a message via AIM to Zippiot
Re: 500 hundreds of a inch
500ths of an inch is much larger than you think, a millimeter is 1/254 (if i remember correctly, maybe 1/245). and 1 millimeter is visible to us, it can be a huge gap with machinery or instruments. a nut that is 1/500ths larger than its bolt wont fit if that gives a better sense...
Unread 18-02-2005, 00:16
JakeGallagher's Avatar
JakeGallagher JakeGallagher is offline
Mmmm Hot Sauce
#0134 (Team Discovery)
Team Role: Operator
JakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant future
Send a message via ICQ to JakeGallagher Send a message via AIM to JakeGallagher Send a message via MSN to JakeGallagher Send a message via Yahoo to JakeGallagher
I don't understand...isn't 500 hundredths of an inch...5 inches?
I haven't updated my signature since last May. Who wants to suggest a replacement?
Unread 18-02-2005, 00:21
punching bag
must have been a typo, but i see your point. he probably meant 1/500ths. lol 5 inches
Unread 18-02-2005, 00:27
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
When someone says a 500th of an inch i think in decimal form, so In his case it would be .0500 which is 1/20 of an inch
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 18-02-2005, 00:28
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
This isn't rocket science:
  • 500 × 0.01" = 5.0"
  • 1.00" ÷ 100 × 5 = 0.05"
  • 1.00" ÷ 500 = 0.002"
  • 1.00" = 25.4 mm
Do you perhaps mean 0.05" (i.e. five hundredths of an inch)? That's not usually something to worry about, when it comes to structural framing. Similarly, it's positively inconceivable that you'd care about 0.002" (i.e. one five-hundredth of an inch) in your frame.
Unread 18-02-2005, 00:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Ugh.. stupid scientific notations.
0.050 or 50 thousandths, is larger than you can think, and may affect form fit or function a bit with robots being 3 feet wide. (If it is an overall chassis cross member dimension).
But, to add to that, a standard dimensional tolerance is +/- .002 of an inch on the parts I make on CAD at work. (Small cable connectors about an inch long (or less) total.) Think: the connector at the end of the cable snake that invades your home and brings you your TV and cable modem services. About that size.
Unread 18-02-2005, 00:36
punching bag
wow my math is off...haven't slept in 2 days...
1/20 is quite larger but .002 in microscopic ( 1/25.4 is 1 millimeter)
what and where exactly did this error occur and is it just annoying or is it a problem?
Unread 18-02-2005, 01:09
To put this in perspective, how many teams are sure that their frame is accurate (in two dimensions) to within 1/16" (0.0625")? (Answer: many, but not a large majority, I would imagine.) How many teams can further guarantee that their frame won't distort this much under normal use? (Answer: few.) If you're cutting with a saw, good luck--the kerf isn't always easy to judge.
I don't think that 80-20 structural framing is in the same league. Really, 2 thousandths is insignificant for the applications that 80-20 makes sense for. I'd guess that a change of 5°C would cause about that much in thermal expansion alone.
Let's see: Δd = d0αΔT; for a 28" piece of framing, α = 23 × 10-6°C-1 (we'll call it constant for small ΔT), at 20°C, in 6101 aluminum (the closest I could find to 6105, which is actually used in 80-20); Δd = (28)(23 × 10-6)(5) = 0.0032"
So if Δd = 0.0032", we're dealing with as much thermal expansion as we have machining tolerance, merely in taking it from the unheated cargo trailer to the pit area. That's why I think 0.002" is crazy, for our purposes.
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
hAS ANYBODY MADE A 3/16 INCH set screw in inventor? Alex Cormier Inventor 2 01-02-2004 20:31
Found the password for the manuals Gary Dillard Rumor Mill 29 10-01-2004 14:54
14 inch bar? hi_im_sean Rules/Strategy 2 29-01-2003 15:35
Indianapolis 500 Greg McCoy Chit-Chat 25 24-05-2002 21:31
