Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 18-02-2005, 03:11
BrianJennings BrianJennings is offline
Sleep is optional
None #1519 (Mechanical Mayhem)
BrianJennings is an unknown quantity at this point
Send a message via AIM to BrianJennings
Cool Backburner Questions
Hello,right now it is 3am where I live and I am comtemplating a problem (which is very common in FIRST, and if you have not found this out, you probably don't realize that there are deadlines!! ). So I figured that I would bring it to the forums.
I was playing around with backburner a while ago and I tried to render an avi using it. I had 2 computers logged into the manager and then I submitted a task to the manager from one of the machines, when I did so it assigned the task to the faster computer and did nothing with the other one. I was wondering if there was a way to have multiple computers rendering one scene at the same times using backburner. Is there an option that I did not set or simthing? Thanks a bunch!!!
-Brian Jennings (Lead animator for Rookie team 1519 Mechanical Mayhem)
"it's googleable " -- the_undefined
Unread 18-02-2005, 05:06
Felipe Reis's Avatar
Felipe Reis Felipe Reis is offline
Wolfgang
AKA: Felipe
#1382 (Tribotec Team)
Team Role: Animator
Felipe Reis is on a distinguished road
Re: Backburner Questions
In order to do that you need to put each Backburner Server into the same Manager..... so when you submit a job both CPUs will work as one....
Felipe
"One Bone to Rigg Them All!"
1382 Animation Team
"TUPY or not TUPY?"
Unread 18-02-2005, 05:13
Sleep is optional
Felipe
I though that is what I did, here is exactly what I did:
Started the manager on my computer.
Started the server on my computer
Started the server on another computer
The manager registered both systems
I submitted the task from my system.
the task got assigned to my system only, it said the other system was idle. I tested it by submitting another task before the first one was finished, then it assigned the seconed task to the other computer.
What did I do wrong?
Thank you very much!
--Brian Jennings
Unread 18-02-2005, 11:49
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
The reason that only one PC is being used is because the output file is AVI. If you want multiple computers rendering at the same time on the same scene, you need to render TARGAS. When the output is set to targas, each PC will render a frame and save the image with a number attached to it. Once you have scene rendered, go into Premiere or whatever post-production program you use and import one of the targas with "Numbered Stills" checked. The program will automatically put together the rest of the targas..
Hope that helps.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 18-02-2005, 19:58
Wolfgang
AKA: Felipe
Team Role: Animator
Hope that helps.
Hey really good help!!! thnx
1382 Animation Team
"TUPY or not TUPY?"
Unread 19-02-2005, 00:42
Sleep is optional
Thank you very much, I tried rendering it to Targa's and it sent the task out to all the systems logged into the manager... Thanks Again!
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
Common Questions with Repeating Answers Tom McCurdy General Forum 1 20-01-2005 15:06
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
3 Questions!!! (2/20/04) Andy Grady General Forum 20 20-02-2004 17:31
