Go to Post I can't wait for the next season to start and my anticipation has already started. But in a way, if you think about it, the season's already started. - nehalita [more]
Unread 17-02-2005, 18:49
wildabyss wildabyss is offline
wildabyss is an unknown quantity at this point
To control motor's rotation...
Hi
I'm trying to control the motor's rotation with a button
I want the motor to turn certain degrees when a button is pressed
so i built a function called MotorDegree, and used For loop to control the rotation. [pwm01 = MotorDegree(p1_sw_trig)]
But it appears that the motor's movement (pwm01) doesn't require the button's activation (p1_sw_trig). It turns automatically once the robot initiates.
I used If command in the function so that the function runs only if the trigger is pressed (when it's 1 or above 0)
What is wrong?
Unread 18-02-2005, 06:32
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Re: To control motor's rotation...
Hi,
How about posting your code for the MotorDegree() function. Are you trying to make the motor turn less than 1 shaft revolution? Or are you trying to use the motor to raise an arm by some angular amount? If it is an arm, what are you using for feedback? A potentiometer?
Regards,
ChuckB
Team 342 Programming & Control Systems
Good luck and have fun!
Unread 18-02-2005, 21:04
Thanks for replying
I found the problem and the thing works now.
Invacare control system, UI? Jacob Morgan Control System 0 24-10-2004 16:54
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
