Go to Post Different approaches to the same problem. Isn't it better to focus on understanding both than to be dogmatic about it? - Greg McKaskle [more]
Unread 18-02-2005, 10:39
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
"Load Bearing Surface"
Who is needing to make design changes to address the Answer to Question 1617?
Q&A 1617
Q: As related to answer 978, Is a robot base considered "in" the loading zone if it isn't touching the hdpe 36" equilateral triangle? If so, What is considered part of the robot base?
A: No. The robot base is considered to be any load-bearing surface within the maximum 28" x 38" robot base size.
Q&A 978
Q: Regarding <G17>: What are the parameters for being "in" a loading zone? (i.e., must some part of the robot be touching the yellow triangle, et cetera)
A: There are no yellow triangles in the loading zones. The robot base and / or drive train must be touching the loading zone. The intent of this rule is that you must be in the loading zone. By making it blatantly obvious that you are in the loading zone, you will draw far less attention from the referees.
We spent all last night trying to ensure that we would not incur a penalty for just touching the loading zone with a "feeler". Just a few of the comments that were lobbed about were
"You've gotta be joking?"
"Looks like we will not be able to cap the center goal with that solution."
"Let's just wait to see if FIRST calls it!"
"It will probably be another one of those 'damage the carpet' rules."
"Do you think our outriggers are considered load bearing if they rub the floor?"
Our team will never intentionally break a rule expecting that the ref will not call it but we also acknowledge that this strategy is commonly utilized in today's society. As the football announcers put it, "If you don't get caught, it's not illegal." Wrong! Breaking a rule expecting the ref not to call it is CHEATING.
Personally, I sure hope that straddling the zone does not turn into another, "They didn't call it during the first regional week so it is okay to do" rule.
Are you in the same boat as we are in?
Lucien
Unread 18-02-2005, 10:56
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: "Load Bearing Surface"
Yes. And what is this nonsense about how it has to be the size of the original robot base. I know for a fact that the manual says the robot may get bigger once the match starts, but if you want to be able to score points I guess not.
Unread 18-02-2005, 11:37
AJunx AJunx is offline
AJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to all
It would appear as if using a flip-down tailgate on the long end of your robot to stow tetras is almost completely thrown out the window.
You could probably redesign such a tailgate so that it works from the side of your robot, if you had another 6 weeks...
Unread 18-02-2005, 12:36
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Originally Posted by Natchez
....Personally, I sure hope that straddling the zone does not turn into another, "They didn't call it during the first regional week so it is okay to do" rule.
Lucien
I'm with you on this one, though most of my team leaders are planning to take this approach. Fortunately, we have been able to change our approach to the autoloader and get teras without changing our design. We just have to make sure a front wheel is on the tip of the triangle.
So our approach is "if they are penalizing the "straddle" we do the "toe touch", if not we go in straight and "straddle"". If it gets to be a real issue then we will make changes at the event. We currently have weight to play with so adding a "load bearing surface" in a convenient place shouldn't be a problem.
I regard the rule as it stands as difficult to enforce at best. Reverting to just having to be in the three dimensional space above the tetra would be a better option. I personally think it will devolve to this in practice if not in the rule book. Every year there are rules that are functionally changed during the course of the season, even if the change never makes it to the rule book. Our team leaders regard this rule as this year's version.
The other rule they feel falls into this catagory is the high speed ramming rule. We are expecting to get hit repeatedly and hard and are designing protective measures. Even if this rule is enforced during the qualification rounds, we are expecting that it will be relaxed in the Eliminations.
If FIRST is serious about these rules, they need to be enforced rigorously at ALL Week 1 competitions. The refs, especially the head refs, need to be experienced and know the intentions of the rules. This goes double for any events that are broadcast or webcast.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 18-02-2005, 17:01
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Well, regarding the "load bearing surface" comment, I think FIRST taught the lesson very well last year that ANY part of your robot which is in contact with the floor is a load-bearing surface. After all, if it's touching at least some amount of weight is being trasferred to the floor, right? I recall losing a few matches last year because we had a string hanging down from our robot when we were suspended from the bar, and of course the rule last year was that you had to be completely suspended - even a piece of string couldn't touch because part of the weight of that string was being supported by the floor!
Unread 20-02-2005, 21:14
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I will tell you FIRST enforced this rule vigorously at the UTC scrimmage (the usual official field shakedown event). We where getting penalized early on because the officials could not see our wheels through CLEAR lexan.
The intent of this rule has become murky to me. It does not do anything to better warn a field worker if the robot is straddling the triangle with its wheels rather than touching it directly. The fact that they waited to week four to create this and came up with this because of people who wanted to use mouse bots or dangle strings over the zone is ridiculous. This was a more significant change to the rules than they realized.
I hope to see some modification of the rule this week. The intent of this rule appeared to be protection of field attendents. However if you have wheels on either side of the zone the attendent should see you coming and you are still following the spirit of the rule.
Back to my point this rule will probably be enforced and the penalties involved will be significant in the the outcome of the matches.
Unread 20-02-2005, 22:58
Billfred's Avatar
Billfred Billfred is offline
I'm reminded of Dean's mention during the 2004 kickoff of what is straddling and what is touching. (Before anyone stones me to death, I know that 2004 means diddly for 2005. Yet it remains true.)
I fully expect ghettofab during the regionals in order to meet however FIRST (and to a greater extent, the refs) intends to regulate it.
Unread 21-02-2005, 18:25
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
It doesn't say it has to be as big as the base. It says that the load-bearing surface must be within the 28"x38" base. I think the intent of the rule is to reenforce <G12>
<G12> The purpose of the LOADING ZONE is to allow ROBOTS to quickly and safely receive TETRAS without interference while HUMAN PLAYERS and/or field attendants are in close proximity, and then return to play. The LOADING ZONE is not intended to serve as a “perpetual safety zone” to prevent interaction with opponent ROBOTS for the entire match. Tethers, tape measures, long extension arms, and other devices intended to contact the LOADING ZONE to maintain the “non-interference constraint” defined in <G15> while the ROBOT drives around the remainder of the field are against the spirit of the rule and will not be permitted. Such devices must be removed before the ROBOT will be permitted to play in the match.
So yes, your robot can get bigger after the start of the match. And yes, you can still score points; but you have to have a load-bearing surface (like a wheel) that lies inside your original base touching the loading zone to receive a tetra.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 21-02-2005, 18:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Why a wheel? From a simple physics standpoint, even a thread would be a load bearing surface. By gravity, the thread is pushing on the ground, and by Newton's third law, the ground is pushing on the thread. Because the thread is mounted to the robot, it is applying some or all (I won't get into complex physics) of the "equal and opposite" force to the robot. You wouldn't even have to explain it this far, since the thread is part of the robot and it is applying force to itself. Since the thread has dimension, it has surface. And because load is being applied on this surface, it is a load bearing surface.
However minuscule, a load is a load and IMHO even a hanging thread would satisfy the rule.
EDIT: However I'm not sure that this will satisfy the "blatantly obvious" rule/suggestion. Also, what is the difference between "in" the loading zone and "touching" the loading zone. It should be blatantly obvious that you are in, but does it have to be blatantly obvious that you touch?
I think FIRST should eliminate the touching rule and keep the blatantly obvious one to eliminate all the "hoola skirt" ghettofab people will be putting on their fine quality machines.
Unread 21-02-2005, 18:47
Originally Posted by sanddrag
Why a wheel?
For purpose of example. *shrug*
I agree with you; technically anything inside the (28"x38") base, that touches the loading zone is a load-bearing surface ... be it a string, wheel, lexan 'tail', PWN cable that came loose in the match, etc etc.
Student - 2001-2004
Mentor - 2006-2009
Last edited by Katie Reynolds : 21-02-2005 at 18:57. Reason: Apparently, I can't spell today...
Unread 21-02-2005, 19:16
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
if the triangle was a box instead this would not be a problem. They got cute with the design and now it is bitting them in the butt. this issue will be up there with tethers
Unread 22-02-2005, 08:53
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Lightbulb Re: "Load Bearing Surface"
Prediction: After Looking at the Q&A's from today, I expect Update 13 to address this issue. No more of this "Load Baring Surface" Junk.
ID:1728 Section:4.1 Status:Answered Date Answered:2/22/2005
Q:Can the automatic loading zone triangle be made larger or inverted so the robots can pick up tetras easier? Many 10 pt penalties at the UTC scrimmage made for very low scores. Robot base dims and triangle dims should be similar.
A:The loading zone triangles will remain at 36" on a side, however, because of various scrimmage results this weekend, we will increase the human player loading box from 36" on a side to 48" on a side.
ID:1715 Section:4.3.3 Status:Answered Date Answered:2/22/2005
Q:
Regarding the answer to ID 1617, do vertical "fingers" (skirt, wire ties, etc.) strategically placed around a base for the sole purpose of touching the loading zone HDPE "make" the robot in the loading zone.
A:
Yes. After attending and receiving feedback from several scrimmages this past weekend (2/19), we will allow robot-base appendages that are within and remain within the 28" x 38" dimensions to contact the loading zone and be legal.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 23-02-2005, 02:23
#0118 (Robonauts)
ADVERTISEMENT - Loading Zone Feelers
Get your loading-zone-feelers here. For the low price of $399, you can forget all of those, "Oh, we got a penalty because we were straddling the loading zone" headaches. With our advanced design, installation is a zip. With our advanced distribution, you can have your loading-zone-feelers TODAY! Please send $390 to
Mississippi Curb Feelers, Inc.
PO Box 55555
The Great Sate of Mississippi
and then with the remaining $9, please go to Home Depot and pick up some wire "zip" ties. As soon as we receive your $390, we'll fax you instructions as to how to properly install the wire ties so they touch the floor . Please include your favorite charity with your payment and we'll send some money to them so we'll get a tax break and will not feel so guilty for gouging you.
Section: 4.3.3
Status: Answered
Date Answered: 2/22/2005 (hours before ship)
Q: Regarding the answer to ID 1617, do vertical "fingers" (skirt, wire ties, etc.) strategically placed around a base for the sole purpose of touching the loading zone HDPE "make" the robot in the loading zone.
A: Yes. After attending and receiving feedback from several scrimmages this past weekend (2/19), we will allow robot-base appendages that are within and remain within the 28" x 38" dimensions to contact the loading zone and be legal.
What! I'm very disappointed in the rules folks at FIRST. I'm not saying that the ruling soon after kickoff
ID: 978 Section: 4.3.3 Status: Answered Date Answered: 1/11/2005
and subsequently, the ruling on February 16th,
ID: 1617 Section: 4.3.3 Status: Answered Date Answered: 2/16/2005
were what I wanted to see BUT this is getting ridiculous.
First of all, it is becoming far to common that when teams don't like a rule, they whine about it until FIRST changes it in their favor. The "put-your-tools-down ... oh, we-mean-put-your-tools-down-then-pick-them-right-back-up" and "no-software-development ... oh, we-mean-that-you-just-have-to-type-it-in-at-the-regional" rulings come to mind for this year.
Second, it sure would be nice for other teams to be part of this magical "feedback" loop so the other teams could express their displeasure about drastically changing a rule. We probably would have said something like, "you know FIRST, we did CHOP A FOOT OFF OF OUR ARM to meet your rule; why should the teams that decided upon the strategy of let's-whine-alot or they'll-never-call-it be rewarded and we end up with a stubby arm."
Third, does FIRST Q&A system work on Saturday? It sure would have been nice for them to change the rule on Saturday night instead of a few hours before ship. I'd guess that the folks that were part of the "feedback" knew that FIRST was going to address the loading zone rule in their favor.
Fourth, even though I disagreed with the initial ruling (had to be touching versus having to be in the 3D space created by some-reasonable-height-vertically-projected-zone [6" high for example]), I was giving FIRST GENIUS points for instantly making the human player very, very valuable with their rulings. Now with the super-duper loading-zone-feelers (just $399 from Mississippi Curb Feelers, Inc.), the human player becomes much less valuable and thus, FIRST loses all of their genius points.
Finally, as I tell Casey, "it's just another problem ... don't whine about it, just solve it." Even though the short-term solution is to make a robot that meets the new rules, part of the long-term solution is expressing displeasure to FIRST about their actions.
Congratulations on making it through the build season ... and my whining,
Lucien
Unread 23-02-2005, 02:48
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
This is bizzare, i think they should change the triangles to rectangles or squares. Look at this picture from the manual, although its specifically mentioning to the human player requirements; it gives a big O.K to the loading process. Now look closely the robot is stradling the trianlge. This is a big blunder by FIRST, they should have never used this picture, our team might be able to add a load bearing surface but what about the other teams do. FIRST should be more considerate about this. Even till now its not crystal clear as to what the rules are regarding stradling. I know FIRST has done a great job creating a spectacular game, but i think they should make it better by changing or atleast not conflicting with their own diagrams.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 23-02-2005, 03:51
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
This may be slightly off topic, but does this requirement apply to the automatic loading station? I read through the rules and the only thing I could find was that robot A may not interefere with robot B while B is in contact with an auto. loading station. It did not explicitly mention that it was illegal to load from an automatic station unless you were in contact with the triangle did it? Is the automatic loading zone being treated exactly like the human zone, or is it different because safety issues do no apply?
Alex
President
Team 1072 Harker Robotics
Ratchet/slip bearing? Ianworld Technical Discussion 6 20-01-2005 13:04
Looking for 1/2" id flanged bearing .25" thick or less (with flange) Travis Covington Technical Discussion 17 12-12-2004 21:26
bearing help jimfortytwo Technical Discussion 9 01-05-2004 06:20
Need A 0.75" ID bearing .DWG Tytus Gerrish Inventor 6 22-10-2003 11:23
Bearing support - Official Mike Martus OCCRA 0 24-09-2002 05:26
