Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 10-02-2005, 20:46
lasoaaro lasoaaro is offline
lasoaaro is an unknown quantity at this point
Exclamation Pneumatic Coding Problem
Hello All FIRST Teams who read this.
My question goes out to the programmers. I was wondering if anyone knew a line of code that we could use to shut our compressor off once the pressure on the pressure guage reached 115psi and turned it back on if it dropped to around 30psi. our mapping is as follows:
digital_io_out17 /Compressor/
digital_io_out18 /Pressure Guage/
If someoue could help us that would be great!
Thanks alot guys
//~!AaRoN!~
Unread 10-02-2005, 20:49
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Coding Problems?
Thanks alot guys
//~!AaRoN!~
I presume you mean the digital pressure switch? If you are, this code is really obvious and I'm sure you'll figure it out if you just think about it. I'll give you a hint: if
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 10-02-2005, 20:54
if... yesh, that's what it is, lol... ok so..uhm, tell me if this is right?
if digital_io_out18 = 115;
then..uhm...? lol sorry i'm not THE greatest with C...
hmm..see i was looking through trying to find a list of acceptable codes in C for robotics but i coudn't seem to find a list so I'm tryin' to figure it out...but you can use then statements..correct..?
Thanks
Unread 10-02-2005, 20:56
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
30psi? You wont be able to do much of anything with 30psi but if you really want it to kick in at 30psi you are going to have to use the pressure transducer and a few if statements. If you want to use the pressure switch it switches off at about 115 and back on down around 80-90 (I think). The code for it is in the default user_routines.c
Unread 10-02-2005, 21:06
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
The line of code that you need is already in the default code. Connect the switch to digital I/O 18, and the compressor to relay 8. You CANNOT power the compressor with a digital I/O pin.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 11-02-2005, 16:24
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Thanks
The pressure switch is connected to a digital input/output. So it can not have a value of 115, or even 30. It can only have a value of 1 or 0. So when the pressure reaches 115 psi is sends a signal (either 1 or 0, i don't know) and when it drops down to 95 psi it sends the opposite signal. The only way for you to read the exact pressure value is to add an additional analog sensor to measure the pressure. But why would you want to turn the compressor on at only 30 psi? That's the minimum pressure needed to run a solenoid! Wouldn't you want to keep your pressure at least half the maximum allowed value?
Unread 11-02-2005, 23:03
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
I think that you are just learning c are you not? you have experience with VB or Qbasic do you? that will help you but C isn't the same.....
when you make an if statement you don't use a then statement like in BASIC.
Take a couple hours and read some documentation. On this site is the official Programming reference PDFs they have code that is specific to the FIRST controller. the 2004 version is what you want there is no 2005 edition. look on page 19 in the gray code box it shows an if statement for an input and a pwm.
http://www.ifirobotics.com/rc.shtml#Programming
A genecic c programming book would be a worthwhile buy.
Have fun you about to become a professional C programmer!
Unread 12-02-2005, 22:32
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Pneumatic Coding Problem
lasoaaro,
There are a few quick things you need to be aware of:
Your compressor should be hooked up to a "Relay" output, not a digital output. On your robot controller, you will see plugs labelled "Relay Outputs." These should be wired to a SPIKE Relay module, which in turn should be wired to your compressor.
The SPIKE driving the compressor should NOT be wiring to a Digital Output as you have mentioned.
Additionally, the Nason Pressure Switch should be wired directly to a Digital Input (not output as you stated - they are the same plugs, but you can configure them to be inputs OR outputs in software). Again you will see plugs marked "Digital In/Out" on the robot controller. Once everything is wired correctly, the correct code to use should be:
relayX_fwd = rc_dig_inYY;
Where X is the Relay Output for the compressor, and Y is the Digital Input for the Nason Pressure Gauge.
I noticed you are located in Peterborough. I don't know if it's feasible to visit Toronto, however if you are having programming difficulties, contact the director for the Regional(s) that you are attending, and they will be able to hook you up with a veteran programmer to assist you, or to arrange a time to visit a nearby team for help.
-SlimBoJones...
Thanks alot guys
//~!AaRoN!~
Unread 16-02-2005, 17:19
scifi3018 scifi3018 is offline
scifi3018 is an unknown quantity at this point
Why in the pneumatics manuel does it state
No specific Digital Input Port is designated for the pressure switch. The Robot Controller must be programmed to react to the Input Port that is connected to the pressure switch
While in the standard progamming 2.2 and 2.4 it says
digital_io_18 = INPUT; /* Used for pneumatic pressure switch. */
And
relay8_fwd = !rc_dig_in18; /* Power pump only if pressure switch is off. */
This is the code that comes pre-programmed into the bot... so why in the manual does it deny it?
Unread 16-02-2005, 21:31
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
this doesnt work for us any suggestions
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 16-02-2005, 21:37
Doesnt work??
Check List:
1) Pump hooked up to a spike relay, hooked up to relay header 8
2) Pressure switch wired between ground and signal on a pwm cable hooked to dig_in 18
3) no rogue programming activitys
4) bot turned on
This should work fine, when the pneumatics get up to 115psi then it shuts off and resumes at 95psi, cant think of any reason why that wouldnt work...
Unread 18-02-2005, 12:11
What the manual means is you can move those around to any digital input and relay combination you choose. The default code is only providing a suggested location, not a required location.
For instance, our team needed digital input 18 for a multi-bit binary switch, the default pressure switch input was in the way (for deeper programming reasons), so we moved the pressure sensor to a different digital input.
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
