Go to Post All robots can be defeated with strategy. - Alexander McGee [more]
Unread 18-02-2005, 13:38
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
Victor and Spike in same circuit?
We have an arm that "back-drives" when a tetra is on the arm and the motor is neutral.
The arm is on a Victor to provide speed control.
A spike would operate the arm too fast.
Can we wire a spike and a victor to the same motor?
Looking to operate it as follows
1. Raise Arm. (Victor controlling speed, spike controlling nothing really passing voltage through)
2. Arm Stopped. (Victor to neutral, spike to brake (rev & fwd = 1))
3. Lower Arm (sam as raise just other direction)
Is this legal?
Would it work?
Any other options we might try?
Thanks in advance,
Phil
Unread 18-02-2005, 13:55
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Victor and Spike in same circuit?
Is this legal?
Would it work?
Thanks in advance,
Phil
Is setting the Victor's jumper to "Brake Mode" (Jumper pins A and B right on the Victor) not providing enough backdrive resistance?
In our team's experience, setting the Victors to Brake Mode behaves very simliar to shorting the motor leads in neutral, and it's all done automatically for you.
If it doesn't provide enough backdrive resistance, you may need a mechanical solution as running your motors at stall to keep it stationary isn't a viable option.
-SlimBoJones...
Unread 18-02-2005, 14:06
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Is this legal?
Would it work?
Thanks in advance,
Phil
No I don't think it's legal. That said, you can try setting the brake mode on the speed controller. If that also doesn't work, you have two choices: one is to try and create a closed loop system through programming to hold the arm steady. The other is to redesign your arm systems such that you get more torque out of your system. You may just be overloading the motor.
Matt
Unread 18-02-2005, 14:25
We already tried the brake mode on the victor. No luck.
I guess 8-11 pounds is too heavy.
No stalling the motor (pwm = deadpan+2) is not a happy solution.
Okay. Mechanical it is.
Another PWM, Servo and a Bar.
(screwdriver in sprocket (ewww) solution.)
Thanks,
Phil
Unread 18-02-2005, 16:57
zdeswarte's Avatar
zdeswarte zdeswarte is offline
AKA: Zack
None #1240 (LHS Robotics)
Team Role: Electrical
zdeswarte is on a distinguished road
Send a message via MSN to zdeswarte
I don't think you can because each victor and each spike needs their own fuses. You could throw some parallels in there but that would screw up all the voltage calculations and stuff; the judges might not like that a whole lot, either. I would say just use the victor unless breaking is that important...
