Go to Post The robot is NOT a lie. - Rick TYler [more]
Unread 17-02-2005, 22:48
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
pic: Team 1501 Tranny
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 17-02-2005, 22:50
JoshL JoshL is offline
JoshL is an unknown quantity at this point
Re: pic: Team 1501 Tranny
Thats a nice transmission. I like the way the motor is mounted. What is that long rod being used for?
Unread 17-02-2005, 22:52
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
That is awesome. How much does it all weigh?
Unread 17-02-2005, 22:53
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
That is a pretty nice looking transmission. It looks like it was built to last a while. That long rod looks like it is connected to the shifter. Which side of the box is the output shaft on?
See you in DC!
Unread 18-02-2005, 07:52
Goober!!!'s Avatar
Goober!!! Goober!!! is offline
I am The Goober!!!
AKA: Steve
FRC #1501 (Team Thrust)
Goober!!! is a jewel in the roughGoober!!! is a jewel in the roughGoober!!! is a jewel in the rough
Send a message via MSN to Goober!!! Send a message via Yahoo to Goober!!!
Talking Re: pic: Team 1501 Tranny
i now it is a nice transmision becuase im on that team it will be the best there is at the compititions we are going to!!!
Unread 18-02-2005, 13:57
AKA: Warthog
The long rod is the shifter. It, along with it's sister will be connected to a double shaft pneumatic cylinder. The shifter consists of two disks with 6 allen head bolts. These match up with the holes in the drive gears. Shift on the fly only.
The weight is 5.5 pounds.
If you look below the shift shaft you will see the output drive sprocket.
The gear ratio at the motor is 5.3:1. It has the same high speed as the two motor tranny supplied in the KOP.
Wayne Doenges
CAD Mentor
Unread 18-02-2005, 14:07
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
Wayne Doenges
CAD Mentor
"double shaft pneumatic cylinder" sounds like you are talking about an illegal cylinder; I am assuming you are saying that you have 1 cylinder with 2 shaft outputs.
Unread 18-02-2005, 22:03
AKA: Warthog
Sorry I misinformed you all.
It's a standard cylinder. One shift rod is attached to the rod, on the cylinder, the other shifter is attached to the other end (body) of the cylinder.
Confused now?
Wayne Doenges
CAD Mentor
Unread 19-02-2005, 02:52
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
I understand...the cylinder is free floating and it not attached to a stationary point. half the distance of travel is used in one direction to push the rod for one tranny and then the rod can't extend further, so the body of the cylinder moves towards the other tranny engaging the second gear. I hope some of you can unerstand that...but I probably confused some of you even more.
See you in DC!
Every team please read and respond! Info wanted for FIRST family tree development! Elgin Clock General Forum 99 12-01-2012 03:03
Kettering Kickoff Matt Attallah Off-Season Events 19 27-09-2004 22:40
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
