Go to Post Swerve Drive (n.) - a set of mechanisms to ensure the robot will sit dead on the field for half of that robot's first event - Kevin Leonard [more]
Unread 18-02-2005, 14:35
reilly reilly is offline
reilly is an unknown quantity at this point
pwms for relays
Hello Teams:
What pwms [number ports] are acceptable to use for the relays to the motors , pneumatics,etc.?
Thanks!
Unread 18-02-2005, 14:43
D.J. Fluck
Posts: n/a
Re: pwms for relays
I'm not a programmer, but I'm pretty sure its safe to say you can use 1-7 (8 is dedicated to the pump, but I'm sure a better then novice programmer could change that). You'll just have to assign your operator control switches to the proper switch in programming
Unread 18-02-2005, 14:44
mgreenley
Posts: n/a
Re: pwms for relays
If you could clarify for what you want to use you want to use a pwm line for, it would be helpful, because as is, I think some posters might be confused as to what you're asking. On the RC, there is a bank of pwm pins and a bank or relay pins, so the two don't need to overlap. Hope this helps (see the below .pdf on the usfirst site and examine the RC)
http://www2.usfirst.org/2005comp/Dra...STRIBUTION.pdf
michael greenley
Unread 18-02-2005, 15:02
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
Re: pwms for relays
PWM's are to send signals to and for the motor speed controllers (vicotrs).
There is a bank if pins for Relays Input/Ouput. 1-8 that you use for the relays which send forward or reverse at full power to a Motor or a Pump.
Hope this helps.
Phil
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
pwms 13 and 15 in autonomous mode Chris Bright Programming 1 24-02-2004 22:25
Brake mode on pwm's snowdragon General Forum 4 23-02-2004 19:11
Mapping Buttons to PWMs actorindp Programming 9 10-02-2004 11:11
Can you use PWMs (Red or Blue) with the edubot controller? Dr.Bot Robotics Education and Curriculum 3 04-12-2003 23:51
