Go to Post If it were easy it wouldn't be worth triple the points, right? - SenorZ [more]
Unread 18-02-2005, 15:21
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Exclamation What are with the Ls in Kevin's code??!!! HELP!!!
what are with the "L"s in Kevin's code?
For example,
in Reset_Gyro_Angle,
PHP Code:
gyro_angle 0L
also:
in
PHP Code:
int cmd_velocity(void)
mrad_per_sec = (mm_per_sec 1000L) / WHEEL_RADIUS;
what are they?
why are they there?
where are they defined?
i'm wondering also because our gyro does not work.
see this thread for more gyro details: http://www.chiefdelphi.com/forums/sh...ad.php?t=33786
thank you for any help in advance!!
~Stephanie
Team 1351
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 18-02-2005, 15:24
jdhawg's Avatar
jdhawg jdhawg is offline
Programmer/Mentor/Parent. Pick One
AKA: Jack D Higgs
FRC #0364 (Team Fusion)
jdhawg will become famous soon enough
Re: What are with the Ls in Kevin's code??!!! HELP!!!
The L (i.e. 97L) means that the value (97) should be stored as a Long, instead of whatever they system default is. (Word, in this case.)
"Opportunity is missed by most people because it is dressed in overalls and looks like work." - Thomas A. Edison
"In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits." - Dave Lavery
Unread 18-02-2005, 16:57
RbtGal1351's Avatar
AKA: Stephanie
FRC #1351 (TKO)
ah, thank you!
~Stephanie
SVR 07: 36th seed
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Some things i'm trying to understand on Kevin's Accelerometer Code Squall Programming 2 03-02-2005 12:01
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
