Go to Post Surely, we've seen enough new and interesting implementations of technology in FIRST that we won't keep limiting our imagination to the tried and true. - Madison [more]
Unread 18-02-2005, 18:15
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Dumb question about wiring custom controls
Everything that I run from the control ports has to be attached to the ground pin right? Whether it be a potentiometer or a switch it needs to have 5v to the 5v pin the signal pin connected to a signal pin and the ground pin connected to the ground. Do I just end up attaching all those grounds and solder them to the one ground pin/s?
Unread 18-02-2005, 22:57
Re: Dumb question about wiring custom controls
Switches connect from ground to the signal input on the OI port. Pots connect from +5 to the signal input on the OI port, with no ground connection.
All the +5 pins and grounds on the OI are connected together, so you can use as many or as few as you want. It's probably both safe and convenient to keep all the controls on each joystick port separately powered/grounded.
Wiring Question SPARKY1688 Electrical 3 18-02-2005 13:22
Wiring a Custom Operator Interface Box JWilliams101 Technical Discussion 2 12-02-2005 22:36
Pressure Switch Wiring Question Matthew_H Electrical 4 16-02-2004 01:25
A question of controls Duke 13370 Electrical 8 11-02-2003 14:47
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
