Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 18-02-2005, 17:53
xFlashbacksx xFlashbacksx is offline
168
AKA: Vanessa
#0168 (Flashbacks)
xFlashbacksx is an unknown quantity at this point
Exclamation Anderson Copper 70 Lugs
We would like to know if the Anderson 70 Copper Lugs need to be used through the whole electrical system or they only need to be used on the battery....thanks
Unread 18-02-2005, 18:02
Erics626's Avatar
Erics626 Erics626 is offline
Cool, Calm, Collected
None #1018 (Robodevils)
Team Role: Electrical
Erics626 is a jewel in the roughErics626 is a jewel in the roughErics626 is a jewel in the rough
Send a message via AIM to Erics626
Re: Anderson Copper 70 Lugs
We used the lugs on the battery and on the breaker panel. They are easy to use, and we have had no problems with them. You should have no trouble using them.
Championship Finalist - 2006 Buckeye Regional (Thanks 461 and 141!)
Fourth Year FIRST Member
Third Year Electrical Team Leader
First Year BEST and FIRST Robotics Team Co-Leader
Second Place - Robotics Competition, 2005 Bearcat BEST
Second Place - BEST Competition, 2005 Bearcat BEST
Most Photogenic - 2005 Bearcat BEST
Most Robust - 2005 Bearcat BEST
Fourth Place - Robotics Competion, 2005 Nationals(South's BEST)
"Get your philosophy from a bumber sticker."-Billie Joe Armstrong
Unread 18-02-2005, 21:02
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
The lugs have to be used on all the 6awg connections, but there shuoldn't be that many. Just the ones on the battery leads, the other half of the battery connector, and the cable from the main breaker to the breaker panel.
see <R48>
That is the only places they are required. If you find other uses, I don't see why you couldn't.
Unread 19-02-2005, 01:59
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
see <R48>
The rule states: The ES-18-12 Battery must use the Anderson Connector and the copper SLU-70 lugs provided in the Terminal Supply Bag. Nothing about using it on ALL 6awg connections, just those on the batteries.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 19-02-2005, 06:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Just so you know Anderson does not make the copper lugs. Anyhow, you can get more at Home Depot if you need more.
Unread 19-02-2005, 12:33
Team Alumni
http://www2.usfirst.org/2005comp/Sec...-The_Robot.pdf
Originally Posted by R48
The ES-18-12 Battery, the Main 120 Amp Circuit Breaker, and the IFI CB/Distribution panel must be connected as shown in the diagram....
and to the right of that is a diagram that shows the SLU-70 (mistyped as SLC though) terminals being used on both sides of the anderson connector, and on the lead going from the aux on the main breaker to the breaker panel.
Those are all the required 6 AWG leads. I don't think using 6awg for a motor lead would be worth the hassle.
How to take apart anderson connectors M. Hicken Electrical 7 03-02-2005 08:53
Restricted to the Anderson Connectors in the Kit? sanddrag Electrical 15 20-01-2005 11:36
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Drill motor copper electrical connector archiver 2001 1 24-06-2002 00:57
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
