Go to Post FIRST things first. - Mike Ciance [more]
Unread 19-02-2005, 08:23
demerski demerski is offline
AKA: JJD
FRC #1027 (Mechatronic Maniacs)
demerski is an unknown quantity at this point
Using gyro with other analog sensors...again
Hi,
There's been a few discussions here about reading analog inputs when using the gyro code, but no solid solutions.
Based on Kevin's "interleaving" suggestion, we've tried to modify the timer interrupt handler to read the gyro on every other interrupt, and use the get_analog function to read the sensors in between...we've tried disabling the timer when servicing the interrupt, resetting the ADC, and so on...so far no success. We can either read the gyro, or the sensors, but not both.
We're not expert programmers here, but I would think using potentiometers and such with the gyro isn't that exotic of an idea...has anyone been able to do this?
Thanks in advance for any suggestions...
- JJD
Using gyro.c with other analog sensors no go Astronouth7303 Programming 17 03-01-2006 21:04
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Gyro Sensors fred Programming 12 22-02-2004 23:07
