Go to Post This will likely fall on deaf eyes but - - JaneYoung [more]
Unread 19-02-2005, 11:09
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
Nasson Pressure + Compressor
just to confirm what i read, would anyone mind telling me if the default code will automatically turn off the compressor or do i need to manually go in and programm it to something similar to this:
http://www.chiefdelphi.com/forums/sh...ighlight=nason
thanks for the help guys
-Rookie plz bear with me thanks!
Unread 19-02-2005, 11:24
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
Re: Nasson Pressure + Compressor
the default code has a line that changes the state of the digital18 based on the value of relay8 (i think it was 18 and 8)
relay_08_fwd != rc_dig_in18;
if memory serves.
Phil
Unread 19-02-2005, 11:27
Kurayami o Samayou
None #1160
alright thanks, meaning that i dont have to code anything else. but then we would have to plug in the relay to that port? (sorry only half knowledgable in electronics, this is my first year and they made me programmer but i seem to branch off into everything else half wittedly ^.^)
Unread 19-02-2005, 11:31
you need to plug the compressor's spike relay into the specific port into the code (i believe it was 8) and the nasson switch to the digital pin specified in the code. use a pwm cable and ignore the center wire, it's not needed.
You really should search before you post as these answers are found in other posts.
Phil
encoders stephenthe1 Programming 61 09-02-2005 15:05
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
