We would like to know if the Anderson 70 Copper Lugs need to be used through the whole electrical system or they only need to be used on the battery....thanks
Re: Anderson Copper 70 Lugs
We used the lugs on the battery and on the breaker panel. They are easy to use, and we have had no problems with them. You should have no trouble using them.
The lugs have to be used on all the 6awg connections, but there shuoldn't be that many. Just the ones on the battery leads, the other half of the battery connector, and the cable from the main breaker to the breaker panel.
see <R48> That is the only places they are required. If you find other uses, I don't see why you couldn't. |
Just so you know Anderson does not make the copper lugs. Anyhow, you can get more at Home Depot if you need more.
Those are all the required 6 AWG leads. I don't think using 6awg for a motor lead would be worth the hassle. Last edited by ConKbot of Doom : 19-02-2005 at 12:36. |
| How to take apart anderson connectors | M. Hicken | Electrical | 7 | 03-02-2005 08:53 |
| Restricted to the Anderson Connectors in the Kit? | sanddrag | Electrical | 15 | 20-01-2005 11:36 |
| Unsafely securing Anderson connector? | Andy A. | Electrical | 20 | 16-04-2003 22:11 |
| Drill motor copper electrical connector | archiver | 2001 | 1 | 24-06-2002 00:57 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
