Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 19-02-2005, 14:18
JoeFryman JoeFryman is offline
Meh.
#0094 (Technojays)
JoeFryman is an unknown quantity at this point
Send a message via AIM to JoeFryman
Autonomous Problem...
We cannot get autonomous_mode to become 1; it is always 0. We hooked up a switch to the Competition port and it didn't work but the circuit does complete between pins 8 and 5 on the DB-15 connector. Help?
100 gmail invites: JTFryman@gmail.com
Unread 19-02-2005, 14:52
katkana katkana is offline
that programmer chick
AKA: Gillian Koch
FRC #1412 (Mercedes Metalheads)
katkana is on a distinguished road
Send a message via AIM to katkana
Re: Autonomous Problem...
I had the same problem... and still have. XP However, what I ended up doing was tethering the RC to the OI and switching to autonomous mode that way. It's annoyingly tedious, but being able to test the mode is better than not.
To switch, all you need to do is turn both the OI and RC on and set the team number to 0000. Disconnect the tether, turn the 'bot off and the next time you turn it on, the autonomous mode should run if you don't have any programming errors. 'Course it may run as soon as the team number has switched, so put the 'bot up on blocks first
Hope this helps!
~kat
And now for something completely different...
GO DRAGONS!!!
Drexel University, Class of 2010
"The definition of insanity is doing the same thing over and over and over and over again, but expecting a different result." ~ Albert Einstein
"Strength is irrelevant. Freedom is irrelevant. Self-determination is irrelevant. Death is irrelevant. You must comply." ~ the Borg
"Therapy is expensive. Popping bubble plastic is cheap. You choose." ~ Unknown
"We're [engineers]! We're the opposite of people!" ~ pirated from Rosencrantz and Guildenstern are Dead!
Unread 19-02-2005, 14:56
Meh.
#0094 (Technojays)
Nevermind, found out that it really didn't work. I accidentally touched the metallic sides of the connector when testing it. Meh.
problem with autonomous that has stumped all programmers so far bd02 Programming 32 10-03-2004 22:22
PWM problem in autonomous outofcontrol Programming 5 27-02-2004 11:58
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
