Go to Post ahhhh, for the good old days, when our robots always seemed to come in well under weight instead of well over... :( . - dlavery [more]
Unread 18-02-2005, 18:24
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
Wiring Nasson switch
We've been looking through the 2005 pneumatics manual and it says to connect the nason pressure switch to the pwm cables but does not give a diagram how. Could anyone please elaborate on how to wire it?
sorry if this shoulda been posted in wiring
-Rookie plz bear with me thanks!
Unread 19-02-2005, 00:34
Eugene_570 Eugene_570 is offline
FRC #0570 (Phoenix)
Eugene_570 is an unknown quantity at this point
Re: Wiring Nasson switch
2 ten3brousone:
This thing my team had to figure out on our own, but now that I know I can share.
To wire the pressure switch to the RC digital I/O you have to use white and black wires of the PWM cable. The red one you don't need, so you can get rid of it. Then just take the black and white wires and connect them to the terminals on the pressure switch, it doesn't matter which one where, because it's just going to be open or closed (current passing through it or not) that's why there's no difference in wire positioning.
Unread 19-02-2005, 11:03
Kurayami o Samayou
None #1160
ah thanks
Unread 19-02-2005, 16:27
reilly reilly is offline
reilly is an unknown quantity at this point
Eugene:
We having trouble with coding for it; our team has new programmers and we aren't sure what to do for the Nasson switch.
Unread 19-02-2005, 17:16
Originally Posted by reilly
Eugene:
The default code is already setup.
No programming necessary if you hook the pressure switch to Digital input 18 and the PWM control cable for the compressor spike to Relay 8.
Wiring a switch stevex Electrical 3 16-02-2005 08:31
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
Free Wiring Diagram! Mike Alighieri Electrical 16 30-06-2003 14:31
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
