Go to Post And I'm sure I speak for most if not all of CD when I say: "How can we help you do that?" - EricH [more]
Unread 19-02-2005, 20:39
gemccnp gemccnp is offline
gemccnp is an unknown quantity at this point
Question Help with error please ? could not find definition of symbol 'Serial_Char_Callback'
Has anyone seen this error before ? If so, do you have any suggestions ?
Make: The target "C:\mcc18\main.o" is up to date.
Make: The target "C:\mcc18\user_SerialDrv.o" is up to date.
Make: The target "C:\mcc18\user_routines.o" is up to date.
Make: The target "C:\mcc18\user_routines_fast.o" is out of date.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Make: The target "C:\mcc18\ifi_utilities.o" is out of date.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Make: The target "C:\mcc18\ifi_startup.o" is out of date.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Make: The target "C:\mcc18\user_camera.o" is out of date.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_camera.c" -fo="user_camera.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Make: The target "C:\mcc18\auto.o" is out of date.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "auto.c" -fo="auto.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Make: The target "C:\mcc18\FrcCode.cof" is out of date.
Executing: "c:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "18f8520user.lkr" "C:\mcc18\main.o" "C:\mcc18\user_SerialDrv.o" "C:\mcc18\user_routines.o" "C:\mcc18\user_routines_fast.o" "C:\mcc18\ifi_utilities.o" "C:\mcc18\ifi_startup.o" "C:\mcc18\user_camera.o" "C:\mcc18\auto.o" "C:\mcc18\FRC_library.lib" /o"FrcCode.cof"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - could not find definition of symbol 'Serial_Char_Callback' in file 'C:\mcc18\user_SerialDrv.o'.
Errors : 1
BUILD FAILED: Sat Feb 19 18:33:33 2005
Unread 19-02-2005, 21:28
Workaphobia Workaphobia is offline
AKA: Jon
FRC #1546 (Chaos Inc.)
Workaphobia will become famous soon enough
Re: Help with error please ? could not find definition of symbol 'Serial_Char_Callbac
I got this error when I tried to drop in Kevin Watson's user_routines_fast.c (for his encoder interrupt module) as a replacement for the file already in my team's version of the default code. I don't remember what version of the code it is, I just know it had a separate file for serial communications.
Anyway, I looked at the original user_routines_fast.c and saw it had an empty function defined to satisfy that requirement, so I just copied it over to the new one and it worked fine.
Printf symbol undefined? Help schenkin Programming 3 08-02-2005 16:14
How to find the moment of an arm Matthew_H Technical Discussion 7 26-10-2004 12:20
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
Want to find out about other teams?? archiver 2001 0 24-06-2002 01:24
