Go to Post Earlier this week it took me a little bit too long to realize that the reason my pen wasn't writing correctly was that it was actually a screwdriver. I'm going to have to ask for a few nights of honest sleep before signing off on a report. - EricVanWyk [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 19-02-2005, 21:36
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: automated can crushers
yea, the problem using a proximity switch, is that it used magnetics, and aluminum is well...not magnetic, it is classifiea as a "non-ferrous", or "non-ferromagnetic" metal.automated can crusher is a neat idea, we had to make hydrolic can crushers for an engineering class, and bot was that fun, we could crush anything that would fit in it. Being automated, I suggest using some type of saftey, if this is a cans go in until its filled to a certain point kind of deal, have a infared beam cutting across the top, and a receiver on the other side, then in your program add a delay, so that if the infared signal was cut off, or if the time it took for the ir beam to bounce off a object changes, and it stays changed for a long enough period of time, and if you had a pair of ir sensors in the "entry tube" to the crushing bin, so that if there was something blocking the ir in the crushing bin, and no obstruction of the ir sensors in the loading tube, it could proceed to crush, if for some reason there was a obstruction in the loading tube, then it would come back with a overfilled warning, or load tube obstruction - and not run until all the conditions where met. After it crushes the cans, perhaps you could have an automatic mechanism to push the crushed cans into an adjacent holding pen/garbage can.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 19-03-2005, 21:39
CraigHickman
Posts: n/a
to follow Kiss, just have two wires on the face of a wood plate, and have them connect a solonoid to it's power source. this would make it so you put the can in, and boom, it's dead.
Unread 19-03-2005, 22:07
I think this sounds more like you dump a bag of cans into the machine, and it crushes them one by one
BTW, you cant get your deposit back if the cans are crushed.
Unread 19-03-2005, 22:28
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
There was a thread on this maybe 2 or 3 years ago. I don't know if you'll be able to find it or not. There was a team who had built a can crusher to use as a fundraising device and my team was contemplating implementing it but we never did.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 21-03-2005, 17:35
Btower's Avatar
Btower Btower is offline
Volunteer
AKA: Ben Tower
Btower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to behold
From a safety standpoint make it as simple as possible. Essentially you want it to be "Inherently Safe" such that you are not relying on controls, sensors, or actions by the loader to keep it safe. For instance feed the cans through a chute which is long enough to keep the loader's hand from reaching the crusher.
Ben
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
Automated Email Jack Website Design/Showcase 4 24-01-2005 14:36
Automated Loading Zones? Deltafrog Rules/Strategy 24 09-01-2005 12:31
Automated Loader without being in loading zone geeknerd99 Rules/Strategy 3 08-01-2005 21:57
