Go to Post Learning by failure is quite common. - Gdeaver [more]
Unread 19-02-2005, 20:27
BaysianLogik's Avatar
BaysianLogik BaysianLogik is offline
Mentor Emeritus
AKA: Matthew Bays
FRC #1523 (M.A.R.S.)
BaysianLogik is on a distinguished road
Send a message via AIM to BaysianLogik
Problems Changing Channel on Yellow Dongle
My team was just at a scrimmage, and everyone had some major issues changing their channel using the yellow dongles on the 2005 controller. I believe we eventually got 3 of the 5 robot's channels changed, one robot used last year's RC, and the last one (us) use channel 40, the default channel. I don't think anyone was able to do it with their original team number, we had to randomly assign numbers. We were using the step-by step process found in the schematics for the dongle, but they didn't seem to work, and had to finagle our way though it, so I dont think anyone at the scrimmage walked away knowing exactly what we had to do to change the channel.
Does anyone have any advice on changing the current years RC to use a different channel?
Mentor Emeritus-Team 1523: Jupiter HS/GE
Former Mentor-Team 639: Ithaca HS/Borg Warner
Alumni-Team 179: Suncoast HS/UTC
Unread 19-02-2005, 20:45
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: Problems Changing Channel on Yellow Dongle
We had a similar problem in the Quincy scrimmage. It seems that there is a defect in this years OI, which doesn't allow dongles to switch the channels if the most significant bit on the team number is a logical 0. The only work around seems to be flipping up the most significant bit on the team number. It will change your team number, but you can change it back when you are done.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 19-02-2005, 21:55
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
2005 OI doesn't need a dongle to change channels, just use the channel switches.
Unread 19-02-2005, 22:04
Mentor Emeritus
AKA: Matthew Bays
Um, What procedure do you use to change it without a dongle?
Unread 20-02-2005, 00:04
Rookie Year: 1234
Oops, forgot that MSB needs to be on, so your team # is higher the 1024. After that just set the channel you want with the channel switches, THEN turn the robot and OI on. Its worked for me.
Unread 21-02-2005, 17:32
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
We had the same problem this weekend. If you set up a bogus team number, we used 4095, you can set the channel.
IFI said something about it when they put out the update to allow us to get to more than four channels. I can't find the document, but the large team number worked. I don't know why.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 22-02-2005, 19:00
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I put together this white paper this morning in an attempt to explain the process of changing the team number so you can change the channel and how to change the channels, its a pretty simple white paper, hope this helps people out.
http://www.chiefdelphi.com/forums/pa...le&paperid=445
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Yellow card / Red card usage at 2004 IRI Andy Baker Rules/Strategy 53 02-08-2004 00:35
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
yellow dongle Ryan Foley Electrical 1 24-01-2003 15:41
Yellow Dongle Plans... archiver 2001 0 23-06-2002 22:51
Yellow Dongle ark_1230 Electrical 5 24-02-2002 17:21
