Go to Post If only more people could have the same attitude toward FIRST as they do toward their fellow teams! - Jaine Perotti [more]
Unread 11-02-2005, 19:24
NapalmJunkie NapalmJunkie is offline
Chief Electrician
AKA: Nexus Trimean
#1633 (Robobuff1.0)
Team Role: Electrical
NapalmJunkie is an unknown quantity at this point
Door Motor Wire gage
This is probably a stupid question but Dose anybody know what is the minimum gage is for wiring the door motor?
Unread 12-02-2005, 01:41
Re: Door Motor Wire gage
The wiring size is determined by the breaker that you decide to use. See <R72> to <R76>, <R83> and Q/A ID 1161.
Unread 12-02-2005, 12:11
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Or, for lowest resistance just use 12AWG everywhere.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 12-02-2005, 13:19
Chief Electrician
AKA: Nexus Trimean
#1633 (Robobuff1.0)
Thank you. your help is much appreciated
If only the rules allowed us to have napalm on our robots.
Unread 12-02-2005, 23:42
#10 has lower resistance than #12 hence the ability to use a 30 or 40 amp breaker with the #10.
Unread 20-02-2005, 10:14
WebWader125
Posts: n/a
This year's rules only specify #12 for the 40 amp breaker, and 14 for the 30 amp breaker.
Unread 21-02-2005, 11:01
Yes,
But don't forget the "minimum wire guage" is not the best for your purposes. My recommendation is #10 for Chalupas, FP, Drills or anything that could be run from a 30 or 40 amp breaker.
Pressure gage on receivers tareyton Pneumatics 2 18-02-2002 21:14
