Go to Post I miss the years when game speculation was based on an actual hint released in the form of unintelligible strings of numbers - tcallan [more]
Unread 20-02-2005, 11:27
robotguy67 robotguy67 is offline
AKA: Mike Smyth
#1501 (Team T.H.R.U.S.T.)
robotguy67 is an unknown quantity at this point
Re: pic: !501 Robot
Yeaterday after we got the front bulkhead fastened down, we put the arm on and did some more testing. With the arm down and fully extended it would hold a standard tetra without tipping. But I wouldn't want to drive it around that way. With the arm up and fully extended up the staircase, the robot was very stable holding a vision tetra.
The whole arm only weights 23lbs and a lot of that weight is in the back. The base is the max legal dimensions (with a little wiggle room), altough it may not look like it in the picture. With the monocoque construction, we should be underweight for once. This would allow us to either put counter weight on the arm or more weight in the back of the base to make it even ore stable.
Mike
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
