Go to Post I think the GDC should force us to use steam engines, but the electrically-inclined folks on my team might stop whining if they're given more to work with. - Madison [more]
Unread 20-02-2005, 14:55
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
After the match
Some team members believe we can have an "override" switch on the robot that will bring down an arm after the match under power. Is this the case?
Thanks
Unread 20-02-2005, 15:31
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: After the match
What we usually did, and what i have seen other teams doing is: the use of the tether cable with ur OI. Its very easy. Plug the tether cable in and bring the arm down, plug the cable out. However, i would say that keep in mind that there are other teams waiting to setup for the next match. We usually lifted our robot out of the field, placed it on the floor, lowered the arm and then took it to the pits on our cart.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 20-02-2005, 15:37
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: After the match
I think the rules say that the judges may allow you to use the tether to get your robot off of the field. But as someone said (or actually probably didnt say) "dont bet the farm on it". And after the match radio communication is disabled, and if the RC cant connect to the OI all motor outputs will be disabled so it isnt possible. If I were you I would do like thoughtful said and plan on removing your robot from the field before using the tether, but if the judges will let you use it on the field then so much the better.
Unread 20-02-2005, 17:00
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Re: After the match
At first they might let you tether on the field, but after a while as the event moves more off schedule they will begin to start rushing the field reset process. This means that they will make you take your robot off the field before you have a chance to do anything so the next teams can set up. This was the way they did it last year and I'd imagine that they will do the same this year.
GO 1403!!!
Unread 20-02-2005, 17:12
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: After the match
From Section 4.3.4 of the manual:
ROBOTS must be designed to permit release and removal of any TETRAS from any grasping mechanism without requiring that the ROBOT be powered up after the match. At the discretion of the field manager, ROBOTS may be powered up and controlled via tether to collapse or reduce the height of the ROBOT to permit safe and/or rapid removal from the field and transport to the pits.
In my experience most field managers don't have a problem with powering up the robot via tether to release a game object or bring in an arm. As long as the tether port is easy to get to, and it won't take long to get the robot off the field, it's usually alright.
Unread 21-02-2005, 21:06
College Student
AKA: Pat Cleary
Re: After the match
Ok, let me restate the question, in a way that will directly address the problem:
We have a 10 foot arm, and we need power to get it down. Our team put a switch that is mounted out of the way of being hit in competition. It will skip the control board and power the arm right off the breaker board. Is this legal?
Hope that clears it up.
Unread 21-02-2005, 21:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: After the match
I don't believe the robot controller will do anything at all without an established "link" with the operator interface. If your "link" is established by the arena controller, you will be disabled. If your link is established by just the OI, (no competition port) you will be breaking the rules. The only way to establish the link is by tether, in which case you may collapse the arm by your standard controls.
The switch was a good idea but I don't think it is possible.
Unread 23-02-2005, 13:17
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: After the match
This is absolutely not legal, and cannot be used. This set up would be considered a custom circuit, and would be a violation of Rule <R53>:
Custom Circuits may not:
• Interfere with the operation of other robots
• Directly affect any output devices on the robot, such as by providing power directly to a motor, supplying a PWM signal to a speed controller or supplying a control signal to a relay module. (Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the robot’s electrical system is acceptable, because the effect on the robot outputs should be inconsequential.)
• Be used for wireless communication, such as sending or receiving a signal to and/or from the alliance station
• Connect to the radio or tether ports on the Robot Controller
If you left this on and shipped the robot with this circuit installed, you will need to remove it when you get to the competition. If the inspectors spot it, they will not allow you on to the field with the circuit in place.
-dave
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
NASA/VCU Last Moments in Final Match Munkaboo Regional Competitions 19 09-03-2004 12:21
Thanks 968 and 294 and last match LA sanddrag Regional Competitions 5 16-04-2003 17:15
How should FIRST Replay a match Matt Reiland Rules/Strategy 4 09-03-2003 11:11
Thanks - Wild Stang - What a match!!!!!! archiver 1999 1 23-06-2002 22:15
