Go to Post What no one knows is that I’m actually wearing fishnet stockings under this gown… as soon as they finish taking all of these darn photos I’m going to show Dave and Amanda who really has the best legs in FIRST!!! - MissInformation [more]
Unread 20-02-2005, 19:08
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Strange Encoder Problem
We have a big problem here at 358, we were testing our encoders, and it seems that in one direction the encoders say that we have gone 20 feet, and when we go in the opposite direction, it says that we have gone 21 feet, while we go the same distance in both directions. Although I am not sure if this is mechanical, software or electronical yet, I was just wondering if anyone else has had this problem, and how they solved it. If no one has had this problem then we would have to account for it in the program, but that would make a big mess in our code, adding an additional two longs for both forward and back and having the total be the difference of them times their proper coefficients of cource, but I would rather not have to do that to the code. So if you have a solution, your help would be greatly appriciated.
- from B B frank
Unread 20-02-2005, 21:24
jjdebner's Avatar
jjdebner jjdebner is offline
Jdizzle
AKA: Joshua Debner
None #0195 (Cyber Knights)
jjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud of
Send a message via AIM to jjdebner
Re: Strange Encoder Problem
which encoders are you using?
- 2004 Entrepreneurship Award, UTC Regional
- 2004 3rd Place, NJ Regional
- 2004 J&J Sportmanship Award, NJ Regional
- 2006 Championship Finalist
- 2006 Innovation in Control Award, UTC Regional
- 2006 Championship Inovation in Control Award
- 2007 Winner UTC Regional
- 2007 GM Industrial Design Award, UTC Regional
Unread 20-02-2005, 21:48
We fixed our highly inconsistent encoder readings in software, by interrupting on both rising and falling edges of the Phase A signal. The apparent root cause of the problem was mechanical jitter, tricking the software into counting multiple times as the encoder stayed roughly in the same place. An electronic solution (search for "7474") didn't fix our problem, but it might for you.
Unread 20-02-2005, 22:20
Kevin Watson's Avatar
La Cañada High School
FRC #2429
What is the actual distance traveled and how many counts per second are you generating?
-Kevin
Kevin Watson
http://kevin.org
Strange Auto Problem NotQuiteFree Programming 6 20-02-2005 17:12
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
