Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Unread 19-02-2005, 09:58
1574aviad's Avatar
1574aviad 1574aviad is offline
Aviad T. Rom
AKA: Aviad Rom
FRC #1574 (MisCar)
1574aviad is on a distinguished road
Send a message via ICQ to 1574aviad Send a message via MSN to 1574aviad
laser pointer
is it legal to use one on the robot?
i mean...i want to aim better
Unread 19-02-2005, 11:08
vicecityman666's Avatar
vicecityman666 vicecityman666 is offline
AKA: Josh
#1247 (ROKS)
vicecityman666 is an unknown quantity at this point
Re: laser pointer
I checked the checklist the inspectors do at the competition, and i didn't find anything disallowing them.
Unread 19-02-2005, 11:54
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: laser pointer
Does it datisfy all of these rules?
<R26> No devices or decorations are permitted on the robot that are intended to jam or interfere with the operation of the vision system (i.e. changing robot color to confuse opponent’s vision system).
<R34> The use of an Additional Part or Material shall not violate any design rule.
<R35> Additional Parts shall not be made from hazardous materials or be unsafe.
Then, follow the flowchart, starting with the question:
Is the part a safety hazard or likely to damage robots, the field, or interfere with humans or the controls?
If you answer yes, then it is not allowed.
Check the flowchart for more details. If you're still not sure, ask FIRST Q&A
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 19-02-2005, 12:04
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: laser pointer
General Match Rules 4.3.3
<G02>
Alignment devices (templates, tape measures, lasers, etc.) that are not part of the ROBOT may not be used to assist with positioning the robot.
As a side note. I have been flashed in the eyes with on the field lasers and REALLY don't believe they should be used.
Unread 19-02-2005, 12:15
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: laser pointer
You certainly won't get a safety award for having such a device on your robot.
Unread 19-02-2005, 13:27
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: laser pointer
Techically, you can have a laser on your robot only if it is a part of the robot. However, as a functional component of the robot, it would need to be powered by the robot's battery and run through the breaker panel.
Zan Hecht
Unread 19-02-2005, 23:21
Alex Minot's Avatar
Alex Minot Alex Minot is offline
FRC #1676 (Pascack Pioneers)
Alex Minot will become famous soon enough
Send a message via AIM to Alex Minot
Re: laser pointer
I dont think it really falls under gracious profesionalism.........and they are a bit annoying and can damage peoples eyes
Unread 20-02-2005, 16:44
ahecht's Avatar
'Luzer'
AKA: Zan
Re: laser pointer
Off the shelf red laser pointers, while annoying, cannot really cause perminant eye damage. The time it would take to damage the retna is longer than the time it takes for the blink reflex to kick in.
Green lasers, or higher power red lasers (Class IIIb and above) can cause perminant damage, but I doubt any teams would use them.
Zan Hecht
Unread 20-02-2005, 20:15
occra 23.
AKA: ryo
None #1481
Re: laser pointer
well i would say rather than wasting time trying to wiggle throught the rules and everyone elses opinion on NOT having one on your robot i think you should just practice that much more as to not need one.
Unread 20-02-2005, 20:25
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Re: laser pointer
A laser pointer is likely to (at some point in some competition, even if it doesn't happen immediately) point in the direction of one of the drivers or human players, temporarily impairing their vision. I believe that this would constitute "interference with humans" and be disallowed under that portion of the flowchart.
If you've got your laser pointer set up so it doesn't point outwards at people, you might be okay. But using one for aim seems likely to also be at eye-level with drivers and human players, and I very much doubt FIRST would permit the possibility of robots pointing lasers at drivers and human players.
Second Annual Laser Quest Lock-in! Gui Cavalcanti Off-Season Events 3 29-04-2004 23:33
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 26-02-2004 15:21
Laser Pointers.. archiver 2001 18 24-06-2002 00:08
laser guidence for a basic stamp brained valve cover racer Andrew Wyatt Technical Discussion 1 05-06-2002 00:14
