Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 20-02-2005, 19:59
SpeakerSilenced SpeakerSilenced is offline
Programming/Electrical Team Member
#0219 (Team Impact)
SpeakerSilenced is an unknown quantity at this point
Send a message via AIM to SpeakerSilenced
Putdata(&txdata)
Do I need to call Putdata(&txdata); everytime I want a PWM value (1-7) to move the motor? and can I call it anytime it changes or are there specific times i can only call it?
I have various loops inside the autonomous loop
Here is a small one
while (movefoward = 1)
			pwm03 = pwm03;
			pwm01=130;
			pwm02=130;
			Putdata(&txdata);
			fowardcounter++;
			if (fowardcounter > amountfoward) //If this has moved for amountfoward loops then stop
				movefoward = 0;
can I do that in order to have those values executed? or do i need to do it another way
"I want to put a ding in the universe" - Steve Jobs
Unread 20-02-2005, 20:44
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Putdata(&txdata)
Originally Posted by SpeakerSilenced
			pwm03 = pwm03;
I don't know the answer to your question, but I suspect it might be 'no'. May I just ask what 'pwm03 = pwm03;' is there for? It seems kind of redundant.
Unread 20-02-2005, 20:57
#0219 (Team Impact)
I dont know really, I thought I would just put it there to keep the same value just incase.
Unread 20-02-2005, 21:24
cdawzrd's Avatar
cdawzrd cdawzrd is offline
Vice-President of Caffine
AKA: Jonathan
#0619 (CA Robotics)
cdawzrd will become famous soon enough
Send a message via AIM to cdawzrd
this is an infinite loop!
you want
while(moveforward == 1). "==" checks for equality. "=" assigns a variable.
I belive you have to call PutData all the time, it lets the master processor know the user processor is still alive. Someone who knows more about the IFI stuff can tell you for sure. I would call it every loop.
Edit: Call the PutData function once per loop. So, you have
void User_Autonomous_Code(void)
Getdata(&rxdata);
//do whatever
Putdata(&txdata);
So every loop, you get data and put it. The master processor will not let the system work if you don't execute Getdata and Putdata once every loop, but only once! Only call putdata at the very end of every Autonomous loop, so you edit your pwm values and do your calculations, then the very last thing is to Putdata.
Cdawzrd
>> www.cdawzrd.com <<
>> www.carobotics.org <<
Unread 20-02-2005, 21:51
#0219 (Team Impact)
Oh, alright... that is going to require a lot of code editing then -_- thanks for finding that error on the assignment I forgot about that.
