Go to Post My grades were horrid when I started, but thanks to the mentors and other students, I'm now a straight-A student. - Bax2996 [more]
Unread 20-02-2005, 14:37
johnnymac4545 johnnymac4545 is offline
johnnymac4545 is an unknown quantity at this point
Exclamation problems with pneumatic tubing in telescoping arm
Our robot is currently designed to use a pneumatic grabber at the end of a telescoping arm. Right now we are currently in a fix as to how we would be able to have the tubing telescope in and out with arm, as well as how to store it when retracted. Any help would be great, thanks.
Unread 20-02-2005, 14:48
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: problems with pneumatic tubing in telescoping arm
Earlier there was a thread about coiling the tubing. Apparently you may not purchase coiled tubing, but you may coil the kit tubing. I dont know how one would do this besides using a heat gun (which I would think isnt legal, but I dont know), so I really cant be of much help, but try searching for "coiling pneumatic tubing" or something along those lines.
Unread 20-02-2005, 19:20
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
From what I've gathered from the FRC Q&A regarding pneumatic tubing, it looks like we're only allowed to use the 20 m of tubing which came in the kit. Which will probably be a big problem at inspection, since I've seen that quite a few teams are using non-kit tubing.
I would be very wary of trying to coil the tubing yourself unless you have a way to wrap in on a heated mandrel - with controlled heat. Heating with a heat gun is likely to overheat the tubing and create kinks and weak points.
ID: 1641 Section: 5.3.4 Date Answered: 2/15/2005
Q: In reference to 1609, Are we limited to ONLY using the 20 meters of pneumatic tubing provided in the Kit of Parts? Therefore, we CANNOT use equivalent tubing with equivalent specs, but different colors. Am I correct in this assumption?
A: Correct.
ID: 1407 Section: 5.3.10 Date Answered: 2/3/2005
Q: Question ID 1179 did not answer the question. After much discussions there has not been a concensus as to whether 1/4" coiled hose can be used for expansion reasons? We would like to see a yes or no answer please.
A: No. It does not pass the 2005 Part Use Flowchart for a fitting or a valve.
The so-so news:
ID: 1671 Section: 5.3.10 Date Answered: 2/17/2005
Q: In response to question 1407, may we make our own coiled tubing out of the tubing provided in the KOP?
A: Yes.
Pete Kieselbach
Unread 20-02-2005, 22:08
Alex Minot's Avatar
Alex Minot Alex Minot is offline
FRC #1676 (Pascack Pioneers)
Alex Minot will become famous soon enough
Send a message via AIM to Alex Minot
You will have to try and design a service loop
Unread 23-02-2005, 22:53
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
We used long lengths of tubing last year for a gripper at the end of our telescoping arm.
We zip-tied the two pneumatic tubing lines going to the cylinder about every 6 inches to keep them together. Then we used a short length of the surgical tubing to help it "recoil" when we lowered the arm.
It worked well and we did not have any kinks or binds in the tubing.
I would NOT try to heat the tubing to make it into a coil. You will most likely damage the walls and then fail the tube just when you need it.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 25-02-2005, 11:19
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
one other way to telescope your tubing would be to make a small hollow rectangular prism (say, 4" x tube width x length of non-telescoping part of arm) and push the tube in and out of this box to keep it from kinking or coiling. (see attachment) the red is nearest the bottom, and the blue is nearest the top. Because the tubing cannot (reference top view) go outside of the box, it must "coil" in and out.
Just a thought from the middle of VUS History.
Squirrel
Name:	pneumatics coils.jpg
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
pic: Team 930 telescoping arm CD47-Bot Robot Showcase 1 13-02-2004 16:24
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
