magnetic sensor
we want to use a magnetic sensor that we found at radio shack. they are made for doors and when you open the door, they beep. we bought one and want to modify it to help track the position of our turret. would this be legal?
thanks justin |
Re: magnetic sensor
Q: Are electromagnets and/or permanent magnets allowed for use on the robot? A: Electromagnets are not allowed. Permanent magnets are allowed as long as they satisfy the 2005 Parts Use Flowchart. |
Re: magnetic sensor
However, he would only be able to use permanent magnets on the arm to trip the sensor. |
Re: magnetic sensor
I agree
On our robot, we are using small magnets in the wheel sprockets with a hall-effect sensor (much more helpful than the gear-tooth sensors!) reading them, and we never saw anything in the rules disallowing that (and we have some real sticklers!!) Sparks |
Re: magnetic sensor
As long as it can pass through the parts flow chart and NOT violate any other rule, it would pass my inspection.
Re: magnetic sensor
| Could a magnetic field around CIMs cause fuses to blow? | scitobor 617 | Electrical | 41 | 15-02-2005 08:56 |
| Making a Sensor Board | SpaceOsc | Technical Discussion | 11 | 15-05-2004 12:46 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Banner Sensor Programming Problem | 2Crisis | Programming | 4 | 24-02-2004 13:40 |
| Quick Optical Sensor Question | zorro | Technical Discussion | 10 | 21-01-2003 06:39 |
