Go to Post If you want something done about it, than do something about it. - Tetraman [more]
Unread 21-02-2005, 10:14
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Quick Question -- keep losing program!
We keep uploading our code onto our robot and after we turn the robot off, the code is lost. Nothing is operational. The lights on the victors are flashing indicating to us that the program has been lost. We thought of the backup battery and we keep replacing it, but it doesn't seem to be doing anything. Does anyone have any other suggestions? Thanks for any help!!!
GO 1403!!!
Unread 21-02-2005, 10:47
Re: Quick Question
Call IFI. Now. Describe your problem. Follow their instructions.
You'll likely wind up concluding that your RC is bad and has to be replaced, but you might get lucky and fix the problem.
Unread 24-02-2005, 03:40
Re: Quick Question -- keep losing program!
Hopefully you've already called IFI and had the problem fixed. If not, when you get to your event, try running the default code and see if it happens. Then talk to the IFI representative there,
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
quick question about qualifying points Hymnson General Forum 4 25-09-2001 21:19
Quick Question, i guess Andrew Rudolph Motors 1 12-08-2001 14:39
