Go to Post Creatively solving problems is part of the fun. Continuous improvement and sustainment of [old] programs is also important. - tim-tim [more]
Unread 21-02-2005, 10:47
Re: The Hall Effect sensor wiring?
Originally Posted by phillutz
Okay here is my problem.
We have wired the sensor as discribed, but the that will only plug into 1 pwm per sensor.
Discussions state that you need to plug A phase into pwm6 and B into pwm 1
how do you wire one sensor to the 2 pwms?
The data sheet shows only one output per device. The output state is different depending on which direction the teeth are passing the sensor. You need to make that interpretation in software.
Please cite the discussion about A phase and B phase.
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
Chairmans Award Dinner With Dean. Josh Hambright Chairman's Award 26 20-07-2004 19:05
hall of fame nuggetsyl General Forum 15 05-05-2002 22:54
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
