Go to Post Thanks, that clears things up a lot, and should probably have been obvious. - Branden Ghena [more]
Unread 21-02-2005, 10:55
Generator of Entropy
FRC #2973 (The Mad Rockers)
converting animation submission to flash
OK, pretend for a minute that I have no knowledge of 3dStudio Max, Movie Maker, Quicktime, or Flash other than clicking on a file a letting it run. Actually, you don't have to pretend because it's quite true.
Our animation team put together a dynamite animation that I understand takes about 240 MB (since the requirement is "well under 250"). I would like to store this animation on our website in some format that can be accessed and played in a reasonable length of time, and I'm guessing that a 240 MB quicktime movie doesn't meet that criteria.
Is there a straightforward way to export this into Flash or Real or something that will compress it or stream it and make it usable, or is that really a labor intensive job?
Unread 23-02-2005, 15:49
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: converting animation submission to flash
When we made a .WMV version (Windows streaming video) of our animation the file size went down to 4 meg - and it looks almost as good as the 133 meg file we uploaded.
There are other compressed video formats out there but they require you to download some sort of driver to view them. I've given up on RealPlayer. It installs way too much junk.
Unread 23-02-2005, 15:51
AKA: Kevin Thorp
If you want, I can convert your animation to .WMV. We use Pinnacle Studio 9.
Unread 23-02-2005, 16:21
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
What about mpeg? I don't know if the quality will drop and/or if it will be a smaller file.
I can convert it to whatever format, but thanks for offering. I just don't know which format is best. How about Flash?
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 23-02-2005, 16:51
AKA: Kevin Thorp
We can generate better quality WMVs for a given file size than MPEG, but why not try it both ways & pick the one that looks best?
I've used an older version of FLASH, but not for videos. It does a great job of compressing line art and 2d animation. Not too sure about video.
Unread 23-02-2005, 23:16
iamnafets iamnafets is offline
Meh?
AKA: Stefan Mai
None #0624 (CRyptonite Robotics)
iamnafets is on a distinguished road
Flash is terrible for compressing video, not only are the files huge, but they are also bad looking (lots of artifacts) in my opinion. The only real advantage there is they don't have to download anything they probably don't already have. I'd probably go with RealPlayer or a WMV, the WMV encoder is free (think real is too?) and you can tweak it to fit best with the bandwidth on your server.
Cryptonite Robotics Team 624
http://www.cryptoniterobotics.com
If it's down, someone needs to buy me a UPS and tell the thunderstorms to stop crashing my server.
Unread 24-02-2005, 09:29
robot180's Avatar
AKA: Jon
I'll use a WMV. Which program should I use to convert it? I was going to use Premiere, but that doesn't work here. (installation problem) I tried After Effects, but that doesn't have WMV as an option for exporting. I saw AVI though. I assume AVI is much larger, but maybe once it is an AVI, I can convert it to WMV.
Basically, how do I get it from Quicktime to WMV?
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
Unread 24-02-2005, 09:36
AKA: Kevin Thorp
We use Pinnacle Studio 9 to create WMVs, but I don't think it'll open a MOV. We had 3ds max output an AVI to start with.
You might try searching cnet or shareware.com for video conversion utilities.
Unread 24-02-2005, 09:40
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
You can always pay the $30 (or illegally, whatever floats your boat) get Quicktime Pro, then convert the mpg into .mp4 file, which is more compressed and better quality.
Unread 24-02-2005, 15:56
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Yov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the rough
Send a message via ICQ to Yov Send a message via AIM to Yov Send a message via MSN to Yov
you should use the XViD codec, I got our animation down to 3.5 mb with no visible quality loss.
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
2005 Israel regional Winner
2005 Radioshack Innovation in Control Winner
Unread 24-02-2005, 16:30
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
You can export a .flv which is a Flash format for video. It isn't that good in terms of quality vs size but you can do a bunch of funky things with it.
But there is no way that I know of, to convert a 3dx max animation to a flash animation. Flash is very 2D based, which would make it impractical.
Your best bet, like suggested above would to be use an MPEG-4 codec (3IVX,DIVX,XVID, etc)
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 26-02-2005, 14:40
syntaxers's Avatar
syntaxers syntaxers is offline
3dsmax Master
AKA: Chi Feng
#0830 (Rat Pack)
Team Role: Webmaster
syntaxers is an unknown quantity at this point
Send a message via AIM to syntaxers Send a message via MSN to syntaxers Send a message via Yahoo to syntaxers
windows movie maker saves in wmv. I got my 90 MB AVI down to 1.6 MB medium-low quality.
- Chi Feng - Team 830 Forums
Unread 26-02-2005, 15:05
Pachu Pachu is offline
CoPresident HRT
AKA: Piyush Agarwal
FRC #0670 (Homestead Robotics Team)
Pachu is an unknown quantity at this point
Send a message via AIM to Pachu Send a message via MSN to Pachu Send a message via Yahoo to Pachu
If you can afford to spend some money try out Swift 3d, heres the link to their website:
http://www.erain.com/
Hope that helps!
Unread 26-02-2005, 18:21
syntaxers's Avatar
3dsmax Master
AKA: Chi Feng
#0830 (Rat Pack)
Discreet has their Plasma product, but costs some money $$$ An alternative is Illustrate 5.3 which is a plugin for 3dsmax which contains a toon-shading renderer and can export to swf. As I recall, it comes with a 30-day trial offer before it is disabled.
Unread 26-02-2005, 20:15
theory6's Avatar
theory6 theory6 is offline
FRC #1241 (theory 6 - team hansen experience of robotic youth)
theory6 is just really nicetheory6 is just really nicetheory6 is just really nicetheory6 is just really nicetheory6 is just really nice
Not contradicting any of the above posts but there is an alternate method of bringing in your animation into flash.
1: First make a new folder anywhere and call it ANIM_FRAMES.
2: In 3DSM goto render (F10) and select the smallest resolution ratio given.
3: Click on the File Types button and the Save As Type dialog box opens. Browse to the new folder called ANIM_FRAMES that u created. Now in the drop down box just below the name box pick the JPEG option. Now press okay or select.
4: You should now find yourself in the Render Dialog again. Make sure you pick your JPG quality as 70% or lower. Higher than that is not required for web purposes.
5: You can play with the rest of the render settings if you want. Make sure you select the ENTIRE TIME SEGMENT option before you render. Now you can click the RENDER button at the bottom.
6: Now it should render all your frames as images and put them in your ANIM_FRAMES folder. It might take some time depending on your animation.
7: Once the rendering is complete, open up Flash MX (I assume your using MX).
8: In Flash insert a movie clip by pressing F8 and picking movie clip. Call the movie clio something like mclAnimation.
9: Now goto FILE>IMPORT and browse to your ANIM_FRAMES folder. Pick the FIRST image that appears in that folder. It should be sumthing like "youranimationname0001.jpg". You have to pick the first image for this to work. Once you select your first image Flash has this great feature where it will ask you "This image is part of a sequence of image. Do you want to import the entire sequence into your timeline?" Obviously you pick yes. Now Flash automatically places all your images of your animation into each frame. You will have some 1000 odd frames, possibly more or less.
10: Now all you have to do is export your flash file as a .SWF and you can upload it or show it playing on your website. I'm wildly guessing your animation should be around 20 - 30MB, perhaps less and you won't need any codecs, plugins, etc. Just Flash Player to view.
This whole process should take you no more than 2 hours, beginner or not.
If you have any more questions, PM me. Good luck!
Visit Our GTR Winning Website: theory6 - Team 1241
151 2004 Animation Submission Aaron Lussier 3D Animation and Competition 0 07-03-2004 14:29
Awesome FIRST Flash Animation... Tom Schindler General Forum 14 06-03-2004 23:16
Team 1049 Animation Submission blueWarrior 3D Animation and Competition 0 01-03-2004 10:23
Team 384's Animation Submission Joe Matt 3D Animation and Competition 11 27-02-2004 20:02
