Go to Post Computers have a nasty habit of doing exactly what you tell them to do instead of what you want them to do. - KenWittlief [more]
Unread 21-02-2005, 04:59
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
pic: Team 1388: Secret Weapon
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 21-02-2005, 05:03
Jeffrafa's Avatar
Jeffrafa Jeffrafa is online now
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: pic: Team 1388: Secret Weapon
Wow.
That thing is awesome! I couldn't stop laughing when i saw it and figured out how it works. Its certianly an interesting and very innovative use of your tools.
Good Job, wish we'd thought of something like that
Jeff
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
not sure if it quite matches the dominate switch
i'm not quite sure what it does now... it looks like the leverage is a bit little... but i'm not really sure
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 21-02-2005, 05:40
FRC #0973 (GRR)
All it does, is keep that gear from backdriving, which keeps us from having to keep the FP motor at a stall. Simply move the motor up, and the servo locks in the "up" position. The shaft with the gear on it, is threaded at the end and has a jam nut on it which the ratchet fits over. The ratchet is bolted to the frame using a piece of 1x1 tubing and some grade 8 bolts.
When you want to lower the arm, pull the stick down. The program sends a small pulse to the FP motor to raise it up (since you cant change directons on a ratchet under load). The servo then puts the shaft into neutral and allows the arm to be lowered. When you let go of the stick, the servo shifts back into the up posititon, making it ready for the next lift.
As for the dominate switch .. heh. This is actually useful
We're predicting judges/field officals at the events telling us we left a tool on the bot before the match starts, one thing is for sure .. it isnt coming off any time soon.
2011: ???
Unread 21-02-2005, 07:17
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
that's pretty cool-- not backing driving is a good idea-- we did that and sorta bent somethings but it's all fixed--good job guys
Unread 21-02-2005, 12:08
RoboticsIsLife's Avatar
RoboticsIsLife RoboticsIsLife is offline
Robotics Girl
AKA: Elizabeth Lanzarone
#0358 (Eagles)
Team Role: Driver
RoboticsIsLife is an unknown quantity at this point
Oh, our dominate switch has a use...but it wouldnt be a Secret weapon if we told you
~Team358
Unread 21-02-2005, 15:18
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Haha, that looks almost exactly what we used as part of our winch last year to hang on the bar! Nothin like good ol' socket wrenches
Unread 21-02-2005, 15:22
Posting messages that just say "Cool dood!!3!! I rilly rilly like it!3!!" is usually just a waste of bandwidth. I try to avoid it.
But in this case I can only say, "Cool dood!!3!! I rilly rilly like it!3!!"
Unread 27-02-2005, 18:55
Garth1388 Garth1388 is offline
AKA: Garrett
FRC #1388 (Eagle Robotics)
Garth1388 is an unknown quantity at this point
We threw this baby together in about 3 hours, two days before ship when we burnt out the FP. Can you say desperation.
"I know not with what means World War III will be fought, but World War IV will be fought with sticks and stones."
-Albert Einstein
Unread 27-02-2005, 19:33
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
we had a closed 7/16th wrench once on our robot to guide rope...but I am sorry that is so funny/awesome...one of the most funny/awesome things in just about forever. How much can that hold?
Unread 27-02-2005, 19:37
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Our arm is only designed to lift one tetra at a time, so we haven't tried any more than that. It already has a little trouble shifting to go down with only one tetra on there, so I wouldn't dare try two. Nonetheless, it achieves its intended purpose.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 27-02-2005, 20:42
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
So if I'm looking at this right, does that servo let the wrench fall backwards so you can lower the tetra.
I love the ghettoness of it.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 27-02-2005, 21:18
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Basically, yes. The servo shifts the wrench between clockwise and counter-clockwise rotation, depending on what the driver is doing with the controller.
So do we.
_
Unread 28-02-2005, 21:06
Masterfork's Avatar
Masterfork Masterfork is offline
Joshua Hunnings
AKA: Fork
FRC #0233 (the pink team)
Masterfork is a jewel in the roughMasterfork is a jewel in the roughMasterfork is a jewel in the rough
Send a message via AIM to Masterfork Send a message via MSN to Masterfork
very creative good job
Unread 28-02-2005, 21:33
Nhiem's Avatar
Nhiem Nhiem is offline
Other
Nhiem has a little shameless behaviour in the past
I agree. It looks like you guys took apart a chainsaw and re-assembled it to fit into your robot =p.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
pic: Team 1388 Teaser Mike Hendricks Extra Discussion 10 27-01-2005 10:28
Kettering Kickoff Matt Attallah Off-Season Events 19 27-09-2004 22:40
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
