Go to Post Note: Please don't actually mob them or cause them any harm. It's just a saying people. :) - CalTran [more]
Unread 21-02-2005, 15:45
shobuda999 shobuda999 is offline
None #1995
shobuda999 is an unknown quantity at this point
quick c question
is it possible to do something like
variable1 = variable2;
if both variables are ints? for some reason, we're not able to do this and I'm pretty sure its allowed.
thanks,
Dan
Unread 21-02-2005, 15:52
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: quick c question
thanks,
Dan
What happens?
Unread 21-02-2005, 15:53
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
it should be fine. what is the code exactly?
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
Unread 21-02-2005, 15:54
None #1995
Originally Posted by Jon236
What happens?
I get a syntax error on the line below, but when I comment out the var1 = var2;
line above it compiles fine
Unread 21-02-2005, 16:17
None #1995
[above]
int counter = 0;
int tracker = 0;
counter ++
[below]
if (counter<60)
arm = 0;
tracker = counter;
else if (counter<tracker+32)
arm = 127;
l_motor=r_motor=191;
tracker = counter;
else if(counter < tracker + 55)
l_motor=r_motor=127;
arm = 255;
this is for dead reckoning without any kind of sensor using a clock of sorts.
i know this seems kind of strange, the reason I'm doing it this way is so I can easily make slight changes without having to change every value
thanks,
Dan
Unread 21-02-2005, 16:32
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
if (counter<60)
arm = 0;
tracker = counter;
arm = 127;
tracker = counter;
arm = 255;
You have it being set between the else ifs.
there is not if that the else is attached to.
This is what is giving you the error, not the variable setting itself, just the placement of the setting.
Also note: you are setting tracker to counter before you check if it less than counter.
- from B B frank
Unread 22-02-2005, 13:51
None #1995
thanks, I don't know what I was thinking. I was trying to get an autonomous mode done an hour before ship
Quick question: Animation rules? Yov 3D Animation and Competition 14 14-12-2004 15:23
A quick IR sensor question PBoss Programming 7 28-03-2004 21:02
Quick Newbie Question Gobiner Programming 5 16-12-2002 12:49
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
quick question about qualifying points Hymnson General Forum 4 25-09-2001 21:19
