Go to Post We'll get through this as a community, this we know. - JaneYoung [more]
View Poll Results: Theory to real
Theory to real was a flawless transition 11 26.83%
We've had some real-world issues, but have worked around them 25 60.98%
We're scrapping some things that went majorly wrong 3 7.32%
Um...antigravity didn't work out, and that was our entire robot. 2 4.88%
Voters: 41. You may not vote on this poll
Unread 21-02-2005, 17:04
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Your theory vs. your capability
Now that your robot is (hopefully) built and tested (to some degree), how well is your design standing up to reality? Is your CG that solid? Your tetra grabber that fast?
Vote, and qualify.
I'll start. Turns out one of our articulated arms motors isn't quite strong enough to lift what it needs to lift in a certain degree range, but we've managed to compensate for that by keeping it out of that degree range using an almost-as-effective pattern of arm movement.
Our CG is pretty solid; we're underweight; and it looks pretty good.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 21-02-2005, 17:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Your theory vs. your capability
The drivetrain is a little louder than expected but should still be a quite solid performer, just as it was designed to be. We are not getting as many shifts out of the air tanks as we expected, but even if you shift ten times per match that is like every 12 seconds. We should not need more than six shifts in a match. The arm is absolutely amazing. Speed is as designed, but length, movement and reach is much more impressive in person than in Inventor. Through about four hours of practicing yesterday, we have found that the whole process of obtaining and stacking a tetra takes a very significant amount of time, but hopefully with more practice, programming, and a few mechanical tweaks that will speed up. For weight we were .25-.5 lbs over, by the end of tonight we will be under.
Unread 21-02-2005, 17:11
AJunx AJunx is offline
AJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to all
Our robot has run head-on into a number of real world issues. The main problem right now is weight. The robot is overweight because key parts (parts that hold stacks of tetras) had to be reinforced.
Once we figure out the weight issue, it looks like our robot will be able to accomplish what we originally set out to do.
Unread 21-02-2005, 17:29
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Yeah, our robot ran into a few issues too. The smallest issue it quite litterally ran into was a wall. Bigger issues it (somehwat less litterally) ran into were the tetra grabber being clunky and not working that well, and the arm actuation being less than perfect. Overall better than last year though.
Unread 21-02-2005, 17:31
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
we are good, except after testing we found a couple of situations where we can freeze the robot completely (ie tetra gets stuck on the lifter arm behind the lifter and can't get off
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 21-02-2005, 17:48
Our robot exceeded my expectations in every way. It was under weight and worked better than I expected. We even survived having another 'bot shove its tetra spike right through our grabber mechanism.
* Loading tetras takes longer than I thought it would.
* Scoring is faster.
* Our 'bot is much more maneuverable than I expected.
* Our fairly short arm stacks much faster than some teams with long arms.
* Our mechanism appears to be bullet-proof, as we went through a couple of hours of driving on Saturday without a failure (this is what you get by allowing a 4x safety factor on your torque calculations).
* In a real match with six robots, I think it will be hard to score more than 3-4 tetras per 'bot, even without much defense going on.
* Our positive-grip tetra holder has some real advantages over passive holders.
I am so looking forward to Portland.
Unread 22-02-2005, 12:57
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
This has been a strange year. Following are some of the reasons:
Every time we weighed our bot is was just barely under weight.
What we said we would build and what we built are the same.
We only had to design one electronics layout (normally 2 or 3).
I'm not saying that there were no issues, that's not reality, but we were able to overcome them without major redesign.
- Gene Falendysz
Unread 22-02-2005, 18:12
Petey's Avatar
Strategy & Gaming
AKA: Chris Peterson
Lucky you.
We allowed a 20% margin of error on one joint of the arm and it turned out to still be too weak.
I think we worked a fix though.
--Petey
Bio:
Unread 22-02-2005, 18:47
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Our robot turned out to be everything we set out for it to be - a fast, precise (well, to a degree) tetra capper that can play both offence and defence. We had one issue with our manipulatr design, but other than that everything has turned out great. The transition from CAD to the "flesh" was probably within a 99% accuracy rate. Everything mechanically is performing just as intended.
So far, so good!
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
pic: 6 speed?? Great in theory - lets see how it works! CD47-Bot Extra Discussion 63 28-10-2008 02:13
String Theory Michael Hill Math and Science 20 02-09-2005 14:11
100yr anniversary of Einstein's Theory of Relativity. Einstein stage the place to be? Elgin Clock Rumor Mill 6 08-09-2004 09:38
my theory on IA robot180 Website Design/Showcase 7 21-10-2003 18:05
Makin' a home-brewn dashboard program, and I need theory help! DanL Programming 33 05-07-2002 01:26
