Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 23-04-2002, 14:27
Lethi86 Lethi86 is offline
#0086 (Team Resistance)
Lethi86 is an unknown quantity at this point
Send a message via AIM to Lethi86
Smile Pneumatics Recycle Can-Crusher
Just wanted to spread the words on our pneumatic can-crusher that we built this year.. our team is TEAM 86 and i hope you guys can spread the words on our can-crusher so that we can help disney recycle cans. just bring the empty cans to our pit area and see how the little crusher works. thanks a lot.
Unread 27-04-2002, 00:21
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Do you have a picture that you can post???
Unread 01-05-2002, 03:19
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Need... pics....
*drool*
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 02-05-2002, 18:14
Pierson's Avatar
Pictures would be great...
I bet that teams could turn this into a recycling fundraiser!
Unread 03-08-2002, 17:36
Still wanting pictures...
/me waits...
Unread 03-08-2002, 20:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I made a pneumatic bridge breaker to test the strength of balsa wood model bridges. I suppose it would work for cans too. We just dial in more PSI until the bridge breaks and the one that broke at the highest PSI is the winner. Do you know of any more acurate way to display the load on the bridge other than PSI reading? We used to just use the good ol' hang books from it method before we built the pneumatic breaker.
About the can crusher, neat idea but I think I would rather spend about 1/3 the time and just step on it.
Unread 05-08-2002, 01:16
What?!
How can you say that?!
You are a robotics person, right?
Spend an hour making it, and spend 0.1sec crushing a can to the thickness of a cd case...
I don't see how someone can rather step on a can than that... it's so... primative...
Unread 05-08-2002, 01:29
How can I say that? We'll just like I did above. I am definitely a robotics person as you assumed but I don't need a machine just to crush my own soda can. Think about it, you would have to place the can in the machine, flip a switch to turn on the compressor, wait for the air tanks to fill, flip the switch to turn off the compressor, turn a pressure regulator to crush the can, and then release all pressure from the system to get the can out. I would prefer the three simple actions of the "primitve" method: put the can down, step on it, pick the can up. The pneumatic bridge breaker however is very worthwhile because it breaks the wood bridge in a matter of seconds with very little setup. The primitve way of bridge breaking required ten minutes of setup to position, hang, and level a platform and another several minutes to place books on this hanging platform.
Compare.
Unread 05-08-2002, 01:35
This thread's about a can crusher, not a bridge breaker (as though a common person needs the ability to apply pressure to a model wooden bridge for stress testing)...
I want pictures, and perhaps to build one of my own...
I think it'd be much worth the effort/time necessary...
That is tall.
Unread 05-08-2002, 02:06
Right you are about the topic of this thread. It's just that the devices are similar so I thought I would post it. No pics of the bridge buster because its locked up at school. Although I still think the can crusher is useless, it suppoose it would still be cool to have one. Did you know that they make trashcans with a manual can crusher built into the lid?
Also, this is totally off topic but a thought just came to me about this thing I saw today. It was an industrial scissorlift that drives around for like painting and changing high lightbulbs and stuff and the way it worked was pretty cool. It had a single long hydrallic cylinder going diagonal from one side of the base to the opposite side of the platform atop the scissors. I'm sure we could do the same for a robot with the optional 24" cylinders we were allowed to order. I would draw a picture but I think it's easy enogh to imagine.
Unread 05-08-2002, 02:40
Stephanie Stephanie is offline
Stew da Baker
AKA: AKA: Steppie86
Stephanie has a spectacular aura aboutStephanie has a spectacular aura aboutStephanie has a spectacular aura about
Send a message via AIM to Stephanie
uh, foto, i don't suppose it would be that hard to design one oneself. no need for pictures, it would be a pretty simple device, no?
Unread 05-08-2002, 03:18
gargargar
I'm feeling too argumentative today...
Yeah, I'm actually rather interested in making one, right now... I doubt the feeling will last too long, though... I'm such a lazy bastard...
Unread 05-08-2002, 06:39
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
you should make one that doees a 12 pack at a time
Where has all the fun gone?
Unread 05-08-2002, 08:03
Rob Ribaudo's Avatar
Rob Ribaudo Rob Ribaudo is offline
only... wait, it's today!
#0810 (Mechanical Bulls)
Rob Ribaudo is an unknown quantity at this point
Send a message via AIM to Rob Ribaudo Send a message via Yahoo to Rob Ribaudo
Why even crush the cans in the first place? Just collect them (non-crushed of course) and when you have alot of them, bring them to a store (more likly a grocery store) that have the machines that give you money for recycling your cans. I'm sorry about not being able to give a better description, but amybe someone else knows what I'm talking about.
Anyway the can crusher would be great to use on cans that can not be recyled in this manor. I hate those cans and would love to crush them.
SBPLI Long Island Regional - Highest Rookie Seed, NYC Regional - Highest Rookie Seed, Rookie All Stars
Robert Ribaudo of the computer group and scouting group on the Mechanical Bulls. Check us out at http://www.shsrobotics.vze.com/
AIM: puzz3dmaster Yahoo: evapilotrob
Unread 05-08-2002, 11:47
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
The Engineer's Method
Of course if you are crushing cans without mechanical aid, you want to use the following method. I practiced it far too many times after I learned it in college (but only on soda cans).
1) Empty the can
2) Place the can on a reasonably level piece of ground.
3) Stand on one foot on top of the can.
4) While balancing on top of the can, reach down and tap both sides of the can simultaneously.
Standing on the can places it under a fairly uniform compression load. Tapping the can causes the side to deflect in, the deflection causes stresses to rise leading to a buckling failure of the can.
The resulting squashed can is nice and compact. Some cautions, wear shoes that will allow air to escape as the can crushes and be sure that can is empty.
Christopher H Husmann, PE
"Who is John Galt?"
oil for for Pneumatics nragod Pneumatics 8 03-02-2003 22:30
pneumatics adamoneDB04 General Forum 1 28-01-2003 11:59
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
PNEUMATICS PLEASE HELP archiver 2000 1 23-06-2002 23:06
pneumatics? archiver 2001 5 23-06-2002 22:18
