Anyone got CMU code for the EDU unit?
I am just learning about programming the EDU unit and wanted to know if anyone had code to use the camera on the EDU. I've been weeding through the v2.4 for the FRC and am running up against roadblocks due to not having the same setup as the FRC unit, so I am just programming to download to the EDU and run with just jumpers on the D I/O-Analog in. Thanks for any help.
| Out of the Box Camera Code | russell | Programming | 9 | 21-10-2009 05:28 |
| Pwm 11, 12 and CMU code | Chris Bright | Programming | 3 | 01-02-2005 19:34 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| Sourceforge for Code Repository and other stuff | SilverStar | Programming | 9 | 15-01-2005 21:16 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
