Go to Post The ChiefDelphi forums are more than just a place for people to kill time and engage in some chit chat. - Karthik [more]
Unread 21-02-2005, 22:39
PI Like Control with Pots
I have run into a problem. Our main arm is powered by 2 fisher price motors, and is subject to backdrive when the arm is extended too much. I have a pot connected to it to drive to pre set positions, and I was wondering if anyone has had experience with coding a control loop that is driven by a potentiometer. Normally, I would research this topic, but with one night left to get this working, I need help.
Right now i am using a basic "check and correct" function. I have the code so when the joystick is neutral, it grabs the pots value. Then in the following program loops if that value deviates from the original, it will drive the motor accordingly. This is not working very well. Our only other alternative is a mechanical brake, but we do not have enough time to do this.
Please help me with this...
Thanks,
Tom
Unread 21-02-2005, 22:43
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: PI Like Control with Pots
A PID feedback loop is what you want. There are many, many threads on this including many with code posted. IM me if you want and I can give you my own code.
Team 1257
Unread 22-02-2005, 02:07
Bharat Nain's Avatar
All I can suggest from my past years experience of working with pots is give it some slack. If you over power it, it will go nuts trying to correct itself.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 22-02-2005, 02:18
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If the point of this feedback loop is to prevent backdriving, have you considered switching the jumper on your speed controllers to active breaking?
The double jointed arm I had the pleasure of working on, last year, had some trouble with inertia until we turned this option on. It worked like a charm.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 22-02-2005, 02:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
LOL! A setting to break it! Anyhow, setting the braking jumper might not stop it, but it should noticably slow it's fall.
Unread 22-02-2005, 02:31
*snap*
*crash*
*FotoPlasma walks away, whistling inconspicuously*
Unread 26-02-2005, 17:38
jzampier's Avatar
jzampier jzampier is offline
Finger Lakes Regional Staff
AKA: Jeffrey Zampieron
no team (-)
jzampier is on a distinguished road
Send a message via AIM to jzampier
for an arm I'd avoid PID control. Usually you can get away with just P control and
you will avoid oscillatory problems that like to creep up with PI control.
The way P control works is very simple.
Take the actual postition of the arm (call it y) (from the pot) and subtract it from
the desired position of the arm. (call it r) (from your joystick/whatever).
This is your error signal value. e = r - y
Assuming your pots are calibrated so zero on the arm is in the appropriate location...
(if not add/subtract a fudge factor to y or r as needed)...
Multiple that error value by a constant... (called P
probably between 1 and 2) which is
determined experimentally...
and output that value + 127 to the motor.
output = 127 + ( P * e )
note that depending on directions of movement, e may be negative
and as such P may need to be negative if you are going the wrong direction.
Should work like a charm.
Matt Leese and I had a P controller working with 340's arm last sunday.
(Although I wanted a PD cause i thought it would be faster and more damped)
Man was it cool to push on the arm and watch it go back to where it was before.
"Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour,
and it seems like a minute. THAT'S relativity." -Einstein
First Resume: (If I can remember)
2001 NJ Regional
2001 Championship
2002 NYC Regional
2003 OH Regional
2003 Championship
2004 OH Regional
2005 Finger Lakes Regional
2006 Finger Lakes Regional (yes!)
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 10-03-2005 21:29
Invacare control system, UI? Jacob Morgan Control System 0 24-10-2004 16:54
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
3-turn pots archiver 2001 2 24-06-2002 01:24
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
