Go to Post OOO-GAH! OOOO-GAH! GRACIOUS PROFESSIONALISM ALERT! - Billfred [more]
Unread 21-02-2005, 22:56
PVC Pirates PVC Pirates is offline
Programmer
#1058 (PVC Pirates)
PVC Pirates is an unknown quantity at this point
Send a message via AIM to PVC Pirates Send a message via MSN to PVC Pirates
printf statements do not display in autonomous mode
When I try to use a printf statement in the autonomous code, nothing displays on the console on the computer that is connected to the RC. I don't know why the printf statements don't work, but the autonomous code doesn't entirely work correctly either. Is it possible that the two problems are related? Even if they are unrelated, I need the printf statements to help me fix the problem.
Any insight into this problem would be appreciated.
In practice, the difference between theory and practice, is greater than it is in theory.
Unread 21-02-2005, 23:04
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Re: printf statements do not display in autonomous mode
Well this might be obvious but have you #included printf_lib.h in user_routines_fast? and are you giving the commands in the while (autonomous_mode) (or whatever it is) loop? I'm not sure what else could be wrong.. sorry :/.
Unread 22-02-2005, 00:41
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Make sure Initialize_Serial_Comms or Serial_Driver_Initialized is called before any printfs...
dunno if that's the error
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unread 22-02-2005, 15:41
If you are using the printf that came with the new compiler you will need:
#include <stdio.h>
in every file you want to use printfs, such as user_routines_fast.c, or else you will neither compile error, nor any printout.
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
