Go to Post Patience is the key to FIRST. - Pavan Dave [more]
Unread 21-02-2005, 16:44
wildabyss wildabyss is offline
wildabyss is an unknown quantity at this point
is the 2004 user interface compatible with the 05 RC?
What about 2003's?
Thanks guys
Unread 21-02-2005, 17:00
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: is the 2004 user interface compatible with the 05 RC?
Yes, we have used our 2004 OI with our 2005 RC. I'm pretty sure you're required to use the 2005 OI at competitions, though.
I don't believe the 2003 OI worked with our 2004 RC, so I doubt it works with the 2005 either.
Unread 21-02-2005, 23:55
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
I assume that the reverse is also true. The 2004 RC will work with the 2005 OI? We didn't pull the current year's RC and need to work on the autonomous code. We plan to use a testbot and the 2004 RC with the 2005 OI. Should work the same, No?
Thanks
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 21-02-2005, 23:59
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
In both the 2005 OI and RC there are some specific designs that run with this years field. At the competition you can only use the 05 equiptment. But if you want to test at home for the next 17 or so hours, the 04 OI should work with the 05 RC, but i dont know if the 05 OI will work with the 04 RC.
-Michael Dessingue
Unread 22-02-2005, 00:00
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
<R54> You must operate your robot with the wireless, programmable Innovation First 2005 Robot Control System. Note: you may use the 2004 Robot Controller, but must upgrade its firmware to the latest 2005 version code by downloading the new code from the IFI website.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 22-02-2005, 05:28
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
basically the 2004 doesn't have a disable
2003 is not compatiable because its not programmed in C
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
White Paper Discuss: Using an Operator Interface with the 2004 EDU RC CD47-Bot Extra Discussion 6 20-01-2004 21:11
GUI (graphical user interface) nzj1 Programming 1 17-01-2003 22:47
