Go to Post Volunteers are in short supply and we always need more. - Koko Ed [more]
Unread 22-02-2005, 02:48
Zalumaskov's Avatar
Zalumaskov Zalumaskov is offline
Premier
Zalumaskov is on a distinguished road
Slowing down Camera drive turning
How can I make it turn at a slower speed when tracking with the following code...
if (p1_sw_trig > 0 && tracking > 0) { //If vision active and tracking use camera data
p1_y = speed_control; //set forward speed
p1_x = pan_position; //set turning rate
p1_x = 255 - p1_x; //invert turn direction
// Steering Compensation
if (p1_x > 135 && p1_x < 225 && steering_comp > 0)
p1_x = p1_x + steering_comp;
if (p1_x < 120 && p1_x > steering_comp && steering_comp > 0)
p1_x = p1_x - steering_comp;
pwm11 = Limit_Mix(2000 + p1_y + p1_x - 127); //uses our ramp
pwm12 = Limit_Mix(2000 + p1_y - p1_x + 127); //uses our ramp
I would change the world but I don't have the source code.
Unread 27-02-2005, 10:11
kokodabear's Avatar
kokodabear kokodabear is offline
HELP!
AKA: Brady
#0686 (Bovine Intervention)
kokodabear is an unknown quantity at this point
Send a message via AIM to kokodabear
Re: Slowing down Camera drive turning
At top of file:
unsigned char slow_down = 10; // Change based on how slow you want
On the line before pwm11 = ...:
if (p1_x > 127 && p1_x - slow_down > 127)
   p1_x -= slow_down;
else if (p1_x < 127 && p1_x + slow_down < 127)
   p1_x += slow_down;
This will decrease the speed by slow_down. You could also limit the maximum turning rate. Ex: if p1_x > 140 then p1_x = 140
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Autonomous Camera Integration GregC Programming 2 06-02-2005 14:34
Slowing Down Drive Motors Arc736UV Programming 5 24-01-2005 22:35
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
